IS200t tune
Old 01-09-17, 08:24 PM
  #181
Sheddy
Sheddy's Avatar
These are the dyno results of the VRTuned piggyback on setting 6 (RED) in comparison to Stock (BLUE) both on 91 octane. As we can see the peak numbers were not drastically improved but the overall powerband gained HP and TQ at certain RPM's especially at 5750 where there was a 24.95 WHP and 22.6 WTQ gain. Thanks to Anthony for getting this done.
Old 01-10-17, 12:40 PM
  #182
E46CT
E46CT's Avatar
Received 2,156 Likes on 1,620 Posts
Nice. Making more power longer is better than simply peak #s. Also relative gains are important vs. absolute #s. All good stuff. Glad to see tuning coming alive. I hope something comes along to make this car interesting enough to keep. Or else I'll just get something better next time.
Interesting how we don't get more than 30% throttle until 4k RPM. How exactly was this verified? Do we have a map/table from the dyno showing this? Maybe that's why our cars are dogs off the line.
However, any 200T owners try brake torquing? Takes a while for the turbo to build up pressure while standing on the brake, but the car launches very hard when you do. Only thing sucks is that it trips traction control... and if you turn TRAC OFF, the "TRAC OFF" indicator blocks the boost gauge. So you can't simultaneously build up max PSI and launch at he right moment. You have to guestimate where the turbo is. I'd rather not subject the tranny to all that boost for longer than I'd have to so I hate not knowing where my boost is. I've only done it like three times though. And the car takes off MUCH differently.
Old 01-10-17, 01:11 PM
  #183
MasonGrey
MasonGrey's Avatar
Matt from OVTuned has all the ECU tables and is working on it. Unfortunately, you'll have to take my word for it as he only showed me on his laptop that the ECU limits you to 30% throttle; I suspect he'll have a blog post up about it soon. The only "evidence" of it at the moment is in the HP/TQ graph (2nd photo), you see the blue line jump above 260TQ before the ECU cuts power to create a flat torque curve.
To answer your question, I have tried launching my car for fun, but it's not realistic to do so at every stop.
Old 01-10-17, 05:03 PM
  #184
Sheddy
Sheddy's Avatar
The 30% throttle sounds about right since I am seeing a few companies coming out with a throttle response device. Apexi has the Smart Accel and Blitz came out with a power thro throttle control.
Old 01-11-17, 06:16 AM
  #185
daniellina
daniellina's Avatar
Guys yesterday i went and i did a couple dyno pulls with the VR racing Tuning box, I have an Injen Intake (Loud af) and a muffler delete. I dynoed without the tune, with the Tune in Setting 6 and then In setting 9. And here are the results. if you want you can contact me through Instagram if you have questions. @danlmt1092
The following 2 users liked this post by daniellina:
Katrcf (03-28-17), Sheddy (01-11-17)
Old 01-11-17, 06:18 AM
  #186
daniellina
daniellina's Avatar
Looking forward to get a downpipe,the car feels way torquier i was running 93 octane and the temperature was 73 f ,On a Dyno Jet the tuner told me that usually he is been told that his dyno reads low so i think is very accurate.
Tg22ar (03-22-17)
Old 01-11-17, 08:59 AM
  #187
gbgary
gbgary's Avatar
i don't see the piggyback unit on their web site. when will it be available?
Old 01-13-17, 05:58 AM
  #188
Sheddy
Sheddy's Avatar
Sneak peek, stay tuned (literally)
Old 01-13-17, 12:04 PM
  #189
IS200TFOWL
IS200TFOWL's Avatar
This has me really interested!! Is this a burger tune, jb4? I just ordered the vrtuned piggy back 2 days ago, I kinda wish I would've waited after seeing this!
Lowered IS
Old 01-14-17, 12:49 PM
  #190
Sheddy
Sheddy's Avatar
Took my car to the dyno today and was pretty impressed with the numbers. All i have is a Burger Tuning intake
I had a slight issue with the new tuning system so i am working on getting that fixed and then i will have i tested again.
Old 01-14-17, 07:50 PM
  #191
Mesh704
Mesh704's Avatar
Why the AFR 14.2 .. don't you think this will harm your engine ..
Old 01-14-17, 07:55 PM
  #192
gbgary
gbgary's Avatar
15.0:1 = Lean
14.7:1 = Stoichiometric
13.0:1 = Rich
looks good to me although it could be a little safer.
Old 01-14-17, 08:22 PM
  #193
Mesh704
Mesh704's Avatar
Mine is 12.7 all the way .. is IS350
Old 01-14-17, 08:31 PM
  #194
Mesh704
Mesh704's Avatar
Hope this picture could explain the AFR for other people
Old 01-16-17, 04:30 AM
  #195
Sheddy
Sheddy's Avatar
I know it's a bit higher than normal but that's what we got on the stock tune.
Quick Reply: IS200t tune
