IS200t tune
#2807
“The JB4 is available both as stand along system and as an upgrade kit to the Stage1 tuner. It adds CANbus control and other features to the Stage1 tuning allowing multiple maps based on expanded engine criteria, smoother partial throttle performance, additional engine safety systems such as lean run or over boost, more advanced logging for those wanting to experience with different fuels and E85 mixtures, boost by gear to improve traction, and much more to come via free firmware updates. While Stage1 installs in under 60 seconds the JB4 install requires an additional OBDII cable to run through an existing grommet in the firewall adding 15-20 minutes to the process.”
#2810
Looks great Z! This used to be in Molten Pearl right?
#2811
Very nice power gains on this TTI Stage 2+ setup!
#2813
Those results are a big difference between stock and tune. What results is this showing tho? The stage 2+ looked like a huge let down from the results posted earlier. Is this showing progress that the limitations are being sorted out or is this just some guys results before and after?
#2814
#2816
