IS200t tune
Old 06-27-19, 01:13 PM
  #3961
1stwrldprb
1stwrldprb's Avatar
any updates on the new data logger for windows 10 users?
Old 06-28-19, 06:28 PM
  #3962
Quillo
10th Gear
Quillo's Avatar
Default Sheddy please help
any idea of where this originally came from. Would love to buy this. Please, lets help find this beautiful part.
Originally Posted by sheddy
this company in taiwan has a pretty cool catch can setup with intake pipe
snead (07-01-19)
Old 06-30-19, 12:24 PM
  #3963
Imran200t
Imran200t's Avatar
Originally Posted by Sheddy
My RaceChip ultimate is up for grabs I'm asking $430 shipped...please message me if you're interested. South FL members you can contact me to try it out
Still for sale? Also, did it change throttle response from a complete stop?
Old 07-01-19, 10:37 PM
  #3964
Jomaduh
Jomaduh's Avatar
Do I need to buy a downpipe to run the OV tune?
Old 07-01-19, 10:57 PM
  #3965
Flash5
Flash5's Avatar
No, but if you do get a downpipe you’ll get even better gains.
Old 07-02-19, 07:17 AM
  #3966
Jomaduh
Jomaduh's Avatar
Thanks, are you running the OV tune right now?
Old 07-03-19, 09:51 AM
  #3967
OrangeVirus Tuning
OrangeVirus Tuning's Avatar
Working on it along side our 1.02 update
Thirst16 (07-03-19)
Old 07-03-19, 10:45 AM
  #3968
Jomaduh
Jomaduh's Avatar
Just bought the OV tune for my car, what kind of power gains should I expect with the tune only? No downpipe or anything else added.
Old 07-04-19, 05:30 PM
  #3969
XxS13Lifex
XxS13Lifex's Avatar
we have made good progress on our tune update already. We are fine tuning the transmission.
I'll probably be the first to say the stock turbo is just too small if you guys want real, real power.
So we've already got a Cast piece being made to flange the stock one to T25, for our bigger turbo
With no throttle limits we are seeing 10-11psi 1rst and 2nd gear, peak 15-16psi 3rd gear, and 17-18psi higher gears.(mid range, it will not hold to rev limit)
The stock turbo cannot sustain 20+psi through mid range with no throttle limitation. It's simply too small. I have one here I have taken apart it's *barely* larger than the stock turbo on a 3.5L Ecoboost, which uses 2 turbos.
So anyways we will have a tune + bolt on replacement bigger turbo setup.
Our goal is 400whp with a EFR 6758.
Have been looking at getting my own flange made as well.. I'm looking at using a T28 directly out of an S15 Silvia... do you think this will be a good match for the 8ar if I want to make around 300-320 whp?
Specs:
* 0.64 A/R Turbine Housing / 62 Trim
* Compressor: T28
* .60 A/R Compressor Housing / 60 Trim Wheel
* Compressor Flow: 31 LB/MIN
Old 07-05-19, 08:58 AM
  #3970
levchik77
levchik77's Avatar
Engine can easy hold 300+ hp.
No turbos or strong tuning for 8AR yet.
Old 07-05-19, 09:38 AM
  #3971
OrangeVirus Tuning
Not entirely true on the tuning side. I think the real reason this platform isn't more popular to tune is because of how limited the stock small turbo is. The general consensus is people think the turbo is capable of way more power than it actually is.
Specs:
* Compressor: T28
We actually already have a flange adapter created for T25. I would use something bigger than a standard T28. Maybe a GTX2871R or GTX2863R IWG
The following 2 users liked this post by OrangeVirus Tuning:
Minitech (07-05-19), XxS13Lifex (07-05-19)
Old 07-05-19, 09:50 AM
  #3972
levchik77
levchik77's Avatar
I know a lot of people who want to change turbo for bigger, but nothing on the market. Do you have ideas for bolt on turbo?
Old 07-05-19, 10:13 AM
  #3973
XxS13Lifex
XxS13Lifex's Avatar
In best case scenario, pretty sure an adapter plate to OEM manifold will get you whatever turbo you want, assuming it fits in the tight space and has clearance for piping etc. and you can clock it the direction you need. Requires some CNC though, along with a dump elbow that can connect to OEM downpipe placement. My fear looking at turbo layouts in comparison to OEM turbo is that the placement might make this tricky in my situation... think I may have to have a whole downpipe made with the elbow built in.
Ok great, thanks for the thoughts! Was a little worried even if the t28 got me to 300 it'd be at max, but can get OEM silvia turbo new for very good price so it was tempting.
I saw a while back you mentioned you were testing a turbo package for 400 whp. Any words you might be able to share about your testing? Have you seen any limitations on the built-in exhaust manifold? Any issues on reliability of parts when pushed further on the car? Is the OEM 8ar intercooler able to handle power if I decide to hold off on front mount for a while?
Old 07-09-19, 11:41 AM
  #3974
JB5674
JB5674's Avatar
Bought OVTune
got registry file. Did that piece
plug dongle in the car and get an error “ internal error 0000002 “
looking to read 2019 nx300 fsport
any help is appreciated
thanks
Old 07-10-19, 05:14 PM
  #3975
OrangeVirus Tuning
Originally Posted by JB5674
Bought OVTune
thanks
Hello,
We are looking into this issue. You are not the only one. It's something to do with the latest windows update. We are working on a new version of software.
Also, we are almost ready to roll out 1.02 update to people.
Finally, I will be unavailable from July 17th through the 22nd, (baby on the way!)
Ricoo (07-11-19)
Quick Reply: IS200t tune
