IS200t tune
#4096
78035 1.02 update:
Mine not so great with the tune...
- Throttle response is too sensitive when off from standstill, it jump forward when pressing the gas pedal a little , it make the car jerky during low rpm
- Gear shift in auto mode roughly shift up and down mostly on low rpm
- All drive modes have the same problem
#4097
I am almost finished with 78132. It's not that it it is too difficult or not, it's just finding all the map code takes time.
This needs to be updated further as we have also completely retuned airload control tables as well
If there is anyone who has NOT received 1.02 update please send us a ticket/email (support@ovtune.zendesk.com)
include:
Name
system ID
ECU ID
requesting 1.02
Future updates after this will be available through flash manager so it won't need requested
include:
Name
system ID
ECU ID
requesting 1.02
#4098
Flash kits are all already sent.
78035 1.02 update:
Thanks I will look into this, as I did adjust the throttle tables, but I can lower them if it is still too sensitive.
Lexus989 (09-22-19)
#4100
This file was already sent to you a few days ago
To give everyone a clear idea here, from when we initially started we had about 5 ECU versions to support. Right now we have 30+ ECU versions, and it is growing. For new or potential customers.. please be aware 2019 ECUs require the most time right now. And also RC200T ecus, as they have additional modes.
include:
Name
system ID
ECU ID
requesting 1.02
include:
Name
system ID
ECU ID
requesting 1.02
#4101
Many more ECUs with 1.02 sent as of this morning.
Please let me know your feedback so we can continually improve to make you guys the best calibration possible.
I've made a second adjustment for NX200 where throttle is too sensitive.
Lexus989 (09-22-19)
#4103
So I installed the 1.02 tune 2 days ago, and the car feels like there's more punch in the midrange, top end power feels about the same. Throttle sensitivity feels about the same to me. I haven't done a full throttle launch or ran it all the way to redline yet, but rolling into the throttle feels like there's more urge. Its not a dramatic improvement but I'll probably go back to the track sometime to see if the improvements I'm feeling is measurable over stock. If it actually runs a faster time, then I'll probably go back and re-dyno the car vs what it put down stock.
#4104
#4105
#4106
I can't answer this question because I have no experience with a piggyback to compare to. This is the only tune I've done on this car. I avoided the piggybacks because I wanted something invisible (no hardware or splicing) and I also like that OVTune can manipulate the throttle to open fully and stay open when my foot is to the floor, unlike the piggybacks. At minimum, throttle response is improved. I thought the car was faster after the first tune until I took it to the track and repeatedly ran slower times than stock. My fastest 1/4 mile time is on the stock tune. With this latest 1.02 tune, again I feel like the car is faster but I don't trust my own judgement based on my experience with the first tune. I will revisit the track for some real numbers.
zhifan1 (09-27-19)
#4109
if you go on the N54tech forum, JB4 founder says the IS turbo turbo is the bottle neck and it's just too small period. so it seems to max out fast whether you go with JB4 or a tune.
personally i'd go with the Jb4 because it's cheaper and reversing it back to stock is matter of two plugs. and no risk at bricking your engine computer
on this level/power level of car with a tiny turbo, there's just not much benefit IMO in getting an expensive tune.
#4110
I went to track last night and unfortunately only got 1 run in, because they were soo busy. On my first and only pass, the car did 15.1@94 mph. Same ET as stock but with a 3 mph gain. This time my 60ft was 2.3 vs 2.1 with the stock run. I'm sure I can run 14.9-14.8s if I get more practice and can bring my 60ft times down to 2.1 like I did when stock. NOW I actually see an improvement with the tune and I'm somewhat satisfied. I will go back to the track an another night and see if I can actually get a 14 second timeslip.
This was also my first time launching and running through some gears since the latest tune. The motor now feels like the turbo4 that it is, vs the stock tune where it felt like a small naturally aspired motor. With the stock tune and throttle limitations, the power would build linearly, and the motor would feel more powerful the higher it revved. It felt like it had more topend power than midrange or low-end power. With the tune, where is some lag until about 2k rpms, then a surge of power and I can feel the power taper off up top. The meat of the power is now in the midrange vs up top. This is nice for daily driving and passing. There's more oomph when rolling into the throttle around 2-3k rpms without needing to downshift.
I will eventually go back and re-dyno but I'm estimating about a 30whp gain, and more in torque. I can feel the gain here is mostly torque/ mid-range power. I'd like to install a DP but that won't be for a while. For anyone looking to mod their IS200t/IS300 for power, spend your money on a tune and downpipe first. I don't think an intake or turbo muffle delete is going to give us much. I do have the HPS intake tube w/ my stock airbox and I've noticed nothing since installing it.
