IS200t tune
#4591
https://gottuned.com/product/lexus-i...upgrade-is300/
#4592
some impressive numbers so far. Their 350 tune only netted 25 with a cold air intake. Now if we could replace or upgrade the intercooler. Also with got tuned turbo swap could make some decent power.
DarthLex (09-27-20)
Minitech (11-05-20)
DarthLex (09-27-20)
Minitech (11-05-20)
#4597
Any chance this reduces turbo lag?
#4598
It helps make you feel it less since the enhanced throttle tune helps but the “turbo lag” is the turbo Doesn’t start spoiling until 3000 rpms and that isn’t changed yet
#4599
A couple questions, if you happen to know:
1. How would this compare to the BMS JB4? I have that now since I am still under warranty. I 've noticed the JB4 makes more power on the low end but feels slower on the top end versus the stock tune. I do like the bluetooth phone app connectivity on the JB4 and I like that I can screen mirror the live gauges to show up on the oem infotainment screen. Anything similar on the D3 unit?
2. Does the D3 Tune easily go back to stock for warranty service?
3. Is the NGauge unit required to be connected to the vehicle after flashing?
4. Does the D3 tune eliminate the throttle limitation at low rpms?
5. When you datalog with the new D3 tune, how much boost is it reading? With the Jb4 logging and on the stock tune (Map 0, JB4 disabled) I've noticed the OEM boost gauge hitting around 15 but the JB4 logging is showing 9-10ish PSI. Not sure if the OEM boost gauge is just off or something else is going on.
Thanks!
#4600
currently I am on Ov 1.02. No issue but the lag is unbearable. Saw Taiwan got similar flash tune and many users commented that there is no lag at all. Almost instant reaction.
Minitech (11-05-20)
#4601
Update here on post 32: https://www.clublexus.com/forums/per...ailable-3.html
Scrabie (10-18-20)
#4602
I think we are in business for some fun! GotTuned released another hybrid turbo for our cars with more power capacity. They upgraded the Billet Compressor and Turbine Wheel from the last hybrid turbo they released. The latter was also lightened. The turbo pushes out 380 horsepower to the crank so I would estimate about 320 to the wheel.
Minitech (11-08-20)
#4603
On a side note, I have a catted downpipe coming in, with sensor provisions where they're supposed to be. Would I need a tune for that?
#4604
JB4 Tune
Hey guys I want to purchase the JB4 tuner box, to anyone who has it did you guys notice a difference? What was the 0-60 difference? And overall how does it drive any issues? Thank You, Guys.
#4605
I've got one for sale with the bluetooth kit. Its great being able to access the tuning, logging and OBD-II info from your phone.
Save a couple hundred dollars:
https://www.clublexus.com/forums/market/955327
