IS200t tune
#4606
Time bring hope again to this thread, dropped my car off to d3 performance for a new turbo and cooling upgrade. Time to finally have some power, how much power? Not a clue, have to wait 2 weeks ish to see.
#4607
Im rooting for ya. I was about to pull the trigger on the GotTuned hybrid turbo, but want to see dyno numbers first to see if its even worth it. not looking for crazy numbers but Ive squeezed every last bit out of the stock turbo and its performance, especially in the high rpms, is downright pathetic
#4608
Im rooting for ya. I was about to pull the trigger on the GetTuned hybrid turbo, but want to see dyno numbers first to see if its even worth it. not looking for crazy numbers but Ive squeezed every last bit out of the stock turbo and its performance, especially in the high rpms, is downright pathetic
#4609
All that said, TTi seems to be my only option for the GotTuned hybrid turbo. I also have a catted downpipe for the NX inbound. Anyone know if I'll need a new tune for that, given the fact that I'm already running a custom one?
#4612
How was the process for TTi's custom tune? I have their stage 1 license but am currently running a custom OVTune. I paid for OV's VFTuner and got it activated, in preparation for a hybrid turbo purchase, but the local tuner who was supposed to work on my file unfortunately passed away.
the got tuned turbo looks good. Went thru the specs etc with one of their techs a while back and it seems good. Only issue I see is when talking to them they tried to tell me that the turbo is a plug and play no tune etc needed when installed. I find that extremely hard to believe. Finding a company to tune the hybrid turbo is difficult. Most companies are not messing with our platform anymore as the demand is low. I have reached out to several places trying to get a dyno tune instead of a email tune with no luck.
chezgk (12-01-20)
#4613
the custom tune is good. We did a few tests and logging to get the tune dialed in. Still need to dyno so we can make a few changes and verify that what I'm running is at peak. We have a mild tune in the car at the moment until i get the dyno done and we can see the numbers etc.
Were you given some sort of "limp" tune to run after the new turbo was installed and before any logging happened? Was the logger TTi's own software?
And yes, I agree that plug and play, no-tune advice for a hybrid turbo that's claimed to be capable of over 300hp is rather questionable. I do plan to keep whatever tune I end up with at 10 to 15%-ish below max power for longevity - 280 on a 320 setup, for example.
Thanks again.
#4614
Thanks for the reply! I don't mind doing logs and remote tunes but do wish there was a way to build on OV's custom tune on my NX, since that was excellent.
Thanks again.
Thanks again.
chezgk (12-02-20)
shumasta (12-12-20)
#4617
Hi,
how i can dyno the is200t.
We try it and had many struggle from the rear axis, i think the traction control has intervened.
The result 181 crank hp and a very creepy power curve.
We have deactivate trc and asc via button (5 sec push).
Have the is200t a dyno Mode? Is the paddle dance needed for a valid dyno result?
Minitech (03-08-21)
#4620
I'm too am still on an old OV tune myself, i would be interested in possibly going to D3 depending on how happy folks are with it when compared to OV, specifically with the transmission as i am not sure if that tune includes the transmission tune as well or only engine? With OV the trans shift point and response is good but the throttle/pedal delay is certainly pretty bad for sure.
