You should know! How's that been treating you? Ever raised the boost?
your bms prototype i ended up with has been good. like it a lot. haven't tried it in stage two yet. the link you sent me has several links of it's own and i'm not sure which to use. i'd try it if i knew.
Glad to hear! I believe it is set at 3-4 PSI over stock in the default setting. If you were to do any bolt on modifications like a down pipe then i would suggest raising the boost, but if you are on a stock motor definitely keep it on the current setup. The full JB4 capabilities are not active for us, but we can change the PSI on the Boost Fail safe option or change to MAP 2 (6 PSI ) which is a more aggressive tune (bolt ons needed).
The secondary cats in which I'm referring to have a honeycomb material inside it just like the primary cats. A resonator has an open pathway with packing on the other side of perforated holes to absorb noise. When I have mine removed I will snap a pic of the inside...
So you're referring to these as the secondary cats?
Has anyone removed these and took a picture of the inside? I thought these were resonators.
I paid $80 to have them removed because I thought the same. The kid just doesn't want to listen. I'm 100% certain these are completely hollow, free-flowing resonators
