Breather or oil catch can?
![](https://cimg5.ibsrv.net/gimg/www.clublexus.com-vbulletin/260x205/2016_05_20_17_18_15_566cb07e918c5f38c483c56c178c54c80856137f.jpg)
If you like your front main seal keeping the oil inside the block I really recommend you pulling a vacuum on your crankcase instead of the just atmosphere venting.
For a big single, ditch the pcv valve as they leak boost at higher psi, and use a baffled catch can from both valve covers to the turbo intake pipe, or to a venturi exhaust fitting if you don't want to use the turbo intake stream.
javeiro
08-12-17 05:16 AM
