Possible Custom Intake
Should I go about trying to create this? Here is a little mock up I did in SolidWorks... It would be basically one of the short ram intakes on the market, but I would cut a hole to have the stock cold air intake line up with the box. The set up would use a cone filter instead of a flat filter. So essentially keeping the same design of the stock airbag to serve as a heat shield and funnel for cold air. Also would have a hole cut out to make it like the Fsport lower box.
I have this ( not my car) when the plastics are on the filter is enclosed fully. Takeda is the manufacturer. AFE sister comapny
