Tanabe left side muffler gasket
For those of you with a Tanabe... I had to replace the driver side muffler gasket where it meets the Y-pipe as it was pretty toasted, the exhaust was from another member here on CL. Bought a replacement gasket directly from Tanabe/More Japan, and after putting it all back together, it appears there's a little bit of a gap right at the top where the pipes meet at the gasket. I'm unsure if this is by design, or maybe it's a bit bent... For the time being, I put some aluminum exhaust tape around the entire area to cover it up as I was getting tired of fiddling underneath the car trying to get it to line up properly, but I swear it sounds a bit off... Got quite a bit of a deep sound in the cabin around 2k RPM, unless this is how the Tanabe is.
I took a picture and circled where the gap exactly is. https://i.imgur.com/9QLNCsj.jpg
