Car turns off the moment the engine is on
Old 02-12-17, 08:48 PM
eeric7
eeric7's Avatar
Default Ignition coil sensor bad and can't connect
I have an ignition coil sensor that I can't connect because the plug broke and doesn't work anymore unable to connect it to the ignition coil , can that cause my car to turn off the moment I turn on the engine and it turns off ,please help
Old 02-12-17, 08:50 PM
eeric7
eeric7's Avatar
Default Car turns off the moment the engine is on
I turn my engine on the moment it's on for 1 second it shuts off ,this was after I changed my spark plug wires and ignition coils , and a sensor from my ignition coil broke so I'm unable to connect it to the ignition coil can that cause my car to turn off if I don't have an ignition coil sensor connected ?
Old 02-13-17, 12:47 AM
eeric7
eeric7's Avatar
Default Ignition coil connector broken
What would happen if my ignition coil CONNECTOR isn't connect because I broke one and don't have it connected ,I turn on my car and it starts but in 1 second it shuts off ,can that be the reason?
Old 02-13-17, 09:56 AM
lexo98
lexo98's Avatar
definetly will. The spark plugs attached to that coil are not creating a spark
Old 02-13-17, 10:16 AM
eeric7
eeric7's Avatar
so without the coil connector on the ignition coil the spark plug connected to that coil is unable to create any spark ?
Old 02-13-17, 12:48 PM
DaveGS4
Forum Administrator
DaveGS4's Avatar
Received 2,237 Likes on 1,356 Posts
Merged threads. Eric, please don't create duplicate threads on the same topic
Michael
10-19-16 08:08 AM
kounmechou
GS - 1st Gen (1993-1997)
12-21-13 09:27 PM
93sc3005sp
Performance & Maintenance
05-03-10 08:26 AM
lemmiewink
22
10-31-08 10:40 AM
Quick Reply: Car turns off the moment the engine is on
