IS200t Downpipe
#61
Thanks! I can definitely say that there is more turbo sound from the de-catted pipe, but it’s still quiet since I’m running the stock midpipe and axle back. As far as performance it can be a mind trick, since I know there is no restriction it feels a bit stronger!
#63
I believe Zcon is running an aftermarket de-catted down pipe without a tune, but he did mentioned that he was getting a CEL, not sure if he got it fixed with the O2 spacer. My CEL is off due to the TTI re-flash.
#68
PPE engineering de-catted down pipe with OEM exhaust system.
#70
Your #1 Lexus Vendor
Can't wait for my customers to get the downpipe!! With an exhaust it probably will sound so good.
-Josh
-Josh
__________________
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Orange County, CA
Sheddy (11-08-17)
#71
Blue- BMS tune with PPE down pipe
Red- BMS tune with stock down pipe
#72
Updated the first page of this thread with pictures.
#73
Do you think there is a noticeable difference in power between TTI 1st gen and PPE de-catted downpipes? I like the fact that the PPE retains the heatshield but there is a guy selling a 1st gen TTI in the classified section for $340 shipped.
#74
Nope, they are both well made products, but i do like the fact that the TTI downpipe has an internal O2 fowler to keep the CEL where the PPE uses a traditional 90 degree spacer. You can still use the OEM heat shield with the TTI since the mounting bracket is still over the turbo. The brackets on the PPE are just for the smaller heat shield pieces.
#75
