2003 Gs430 issue after timing belt kit done.
Old 03-30-17 | 01:08 AM
dtwolf's Avatar
dtwolf
Default 2003 Gs430 issue after timing belt kit done.
I have a 2003 gh430 with 109,411 miles. I bought the aisin timg belt kit. Replaced the timing belt, drive belt, water pump & gasket, o-rings,thermostat & gasket, camshaft seals, idler 1 & 2, hydraulic tensioner, NGK IX Iridium spark plugs, covers for the pedals except gas pedal cause it was to long. Now the vsc light & check engine light is on.
Old 04-05-17 | 09:19 PM
RamAirRckt's Avatar
RamAirRckt
Disconnect battery for 30 min and then reconnect.
ANYTIME you see VSC/Check Engine light on and don't have a clear reason why, force it to be cleared. Seen it too many times set for no legit reason.
I did my timing belt and got the drivers side (left) cam off by 1 tooth and didn't realize it till I started it. It came up with a code, but no VSC/CE light. I had to go back in and fix, not a real big deal.
Hopefully all is ok, should be.
Old 04-06-17 | 09:23 AM
eicca's Avatar
eicca
Did you start the car with the wheels off the ground? That set off the lights in mine once. I put it down, cleared the codes, and was fine.
Old 04-06-17 | 11:49 PM
dtwolf's Avatar
dtwolf
The wheels were on the ground and i will be buying a new battery so i will not connect it for 45 minutes to see if that does anything
Old 07-14-17 | 11:11 PM
dtwolf's Avatar
dtwolf
The vacuum hose was knocked off. Jus had to reattach it. Check engine light oooooooooooooooff
suprababy (07-16-17)
boatable
06-03-15 11:24 AM
gregcwert
RX - 1st Gen (1999-2003)
02-26-13 12:32 AM
BDSL
06-02-12 03:14 PM
SEXYCOUPE4
Performance & Maintenance
10-03-07 03:05 PM
sxwk12
04-23-05 11:59 PM
