Turbo IS300
Thanks for the info Turbo, i am going to call them today about setting something up and take a flight out there to see the shop and what not..How far from the shop do you live? I would like to see your car... if you have time..
That thing is super nice...
I live only about 15 min from XS... If you do go down there let me know. I see if I can bring the car down....
Also I'm taking the car down to shinestreet this saturday for an IS300 meet.....
TurboIS--- I am flying out from PA in a few weeks and would like to meet up to check out your IS..... also is ther any way you can post some pics of your rear bumper? is it stock or the Cwest Bumper.. I am not into body kits but I need to find a Front bumper (intercooler)and possibly a body kit to match.. do you know of any good lookin kits besides the Cwest Kit?
Also what problems if any are you having besides the tranny issue.. if you want to take this off forum I understand... I would like to speak to you to talk about all this... I am stoked to get this werk finally done.. after askin so many questions and lookin into so many different companies and peicing actual kits together myself..
thanks Brian
thanks Brian
Hey Turbo.... do you have your Dyno Posted? I was curious as to what your Torque curve is like? how much lag are u gettin at both streetable(7psi) and race levels (12Psi) and you say you are gettin 400rwhp? is there motor werk done or completely stock? how is the reliability of the kit? as far as on the motor and all?
thanks
thanks
James,
if you talk to the XS guys tell them the Guy in philly with the IS wants the turbo kit... I will call them tomorrow to try to werk out details....
I wish I did not need a bumper kit to fit the intercooler.. also I hope I get the Long Tube Header.... ceramic coated and all... lol thanks for all your help
the reason his car is making big power at 13psi is because there still running stock10.5-1 compression.....not healthy on a turbo motor over 10psi....also i dont think the car ever sees 400+ hp on the streets.....turbo is...does the car shift right at over 6psi at wot?.....the tube header helps by maby 20hp or so but like i said before...cracks and leaks are going to be a problem in the future as it cycles through heaing and cooling ...expansion and contraction...also the car is still running stock 330cc injectors with alteres fuel pressure......stresses out the factory squiters....turbo is do you have a fuel pupm upgrade in the car?.....Jeff
