Idea? 2JZ-GTE, conversion to a full manual?
Old 07-02-03 | 09:10 PM
ChrisFL's Avatar
ChrisFL
Default Idea? 2JZ-GTE, conversion to a full manual?
Ok, this is not something I'm planning to do, since I want to keep my car nice and reliable...BUT. I know a lot of people who have considered doing the Supra 2JZ-GTE swap. And the issues involved have already been mentioned in several threads that I've searched
But, let's say you want to convert it to a manual transmission as well? There are some options, take an IS manual, ok, or the Supra, but what about the clutch pedal? Would it be way out of the realm of feasibility to relocate the parking brake lever, and use the parking brake pedal for the clutch pedal?
With my knowledge of cars and manuals being about 1/2 of what many people know, this is just something I thought of. I know the pedal is a bit far to the left, but I could get used to it, if I really did want to try something crazy like this.
Old 07-03-03 | 01:00 AM
JZS14SEVEN's Avatar
JZS14SEVEN
Default both
"Tilton" pedal assembly
i've seen a coupla 147 ARISTO's with manual conversions @ T.A.S. parking lot
cars were all beat up tho.. getto fab
Old 07-03-03 | 07:21 AM
Guru's Avatar
Guru
It can be done no problem but is obviously custom fabbing and I'd say many of thousands of dollars just for labor. As for the ECU you'll have to use a Supra manual ECU that correesponds to that motor and you may lose a lot of current things. Not sure how it will effect things like your dash/instruments, traction control and many others.
Old 07-03-03 | 10:37 PM
v300's Avatar
v300
You're fine. Fabbing is easier now for the project... thanks to Factory wiring harness (US Supra TT MKIV) and AEM EMS.
salimshah
Performance & Maintenance
17
07-03-16 11:34 PM
estomax
SC- 1st Gen (1992-2000)
05-02-15 09:05 AM
trufanatic
02-17-10 07:33 PM
FL1PP3D
05-11-07 12:43 AM
