I picked up the classic INVIDIA Q300 for my 2017 IS300. I had not seen many pics of that exhaust with the 2017 diffuser so I was not sure what to expect.
The install went great, no issues. The fit looks good!
Thought I would add some more to the discussion about the Q300. Now that I have driven it around a couple of days, I agree with the posters who say that it is very quiet.
At low RPM, there is a small GROWL, but not much at high RPM.
Since I have the AWD, I can't add on the mid-pipe. Guess that will be it for now. Still like it though, but it could be a bit more noticeable.
Midpipe: I had a quick look around but only found the RWD model. I'll look again to see if there is indeed one for the AWD.
Drone: very minimal. You hear it a bit when you just touch the throttle. In traffic, its not too bad. On the open road, there is really nothing "annoying" about the sound. I still haven't heard it from outside the car myself. I'll get a buddy to do some drive-bys to hear it.
I wonder if the ECU somehow adapts to the new exhaust conditions and changes the way the engine responds. That could explain the change in exhaust noise over time.
AWD owners order the RWD mid-pipe. exhaust gets louder as the fiber glass packing in the muffler “breaks down” or whatever. it will get louder. just wait and then decide if you need the midpipe.
keep in mind, it sounds different in the cabin as opposed to being outside your vehicle. the full catback is pretty loud and will instantly draw attention to your vehicle.
I just put on my Invidia Q300 + Midpipe about a couple month ago and I personally love it. Its not really that loud when you're cruising but when you step on it, it sounds amazing in my opinion.
Just installed the Q300 on my IS350 on Friday. Other members have mentioned waiting for about 500 miles until they noticed increased sound. Also read part of that is due to the ECU needing to adapt as well as the fiber glass in the muffler.
Personally, I agree with most so far. Its almost perfect but needs a little more. After a few weeks if I'm not satisfied I will have the resonators removed (rather than an entire mid pipe).
After a few weeks of driving with the Q300, I agree it now makes a little bit more noise, but its still quite discreet.
I did have an issue with the muffler on the passenger side falling off the rear mounts though! The way the steel rod is made, with no "nipple" on the end, it was able to side right out of the rubber holder (see image below). The exhaust tip was hitting the road on the highway. Not great. I fixed it for now by putting a hose collar on the tip of the steel rod.
Did you do the mid-pip install yourself? If not, what shop did you have it done at or recommend to? Hopefully in Socal?
I have a driving video, taken after having driven approx. 500-600 miles on the newly installed Q300 (IS350). Sounds great. I like the discreetness under 4k rpm. I will edit post in performance when I get a chance...soon.
Is the '500 miles' break-in period strictly for when Q300 is paired with the mid-pipe or for the axle-back itself?
my understanding is it that break in period is for axle-back (mufflers particularly), but also ECU.
I can attest it has increased in sound. I think there can be something said for pipes themselves becoming kind of resonated in regard to mid pipe or any exhaust pipe but dont imagine that would change much for sound. I may be incorrect on that.
