Gs400 problem codes??
So since my 98 gs400 has been giving me some acceleration problems. And now that my check engine light is on...three codes showed up.. P0441,P0446,P0505...any suggestions on where i should begin the repair process???
po505 is erratic idle speed usually due to loose air intake hose. the code sets when there is an air leak after the throttle body and the engine computer is doing everything it can to maintain a steady idle. and since you have two evap codes i suspect possibly the evap lines on the driver side of the motor above the valve cover are torn or came loose from a bad driv. side engine mount. purely speculation since i dont have the car in front of me to diagnose but check in that vicinity first.
Vogel1118 (06-25-18)
nah it isnt really that sketchy at all. use the little tube that comes with the can to help pinpoint possible problem areas, and to make sure you can isolate where it is spraying to so you dont get a reaction and not know exactly where it came from by spraying too large of an area at once.
91LS400LEX
24
09-07-10 01:36 AM
vstolyarov
04-13-07 04:41 PM
