02+ Aristo Swap w/ A340e 4AT Questions
Old 02-04-19, 05:04 PM
ElitistK
ElitistK's Avatar
Default 02+ Aristo Swap w/ A340e 4AT Questions
Hi guys! Those of you who have done an Aristo swap using the TT 4spd auto into a 02-05 IS/GS300, how did you wire the ECU input pins for A/T Indicator P and R gear?
On the 01/Aristo harness, P and R pins are on the body plugs going into the ECU. On the 02+ harness, they are on the engine plugs going into the ECU. Not sure why Toyota would make a switch like this, but using Aristo everything (ecu, tranny, harness) means I need to get the P and R signal from somewhere. Technically both wires should lead to the Shift Indicator right on the tranny itself, but I haven't gone as far as tracing the wires on the '01 body harness to see exactly where it leads to.
Old 03-26-19, 06:56 AM
rayjaygs97
rayjaygs97's Avatar
Ik this is an old post, but do you still have the rest of the wiring setup? im looking to gte swap my 05 gs.
grupple
07-24-18 10:11 AM
1sxyrxy
GS - 1st Gen (1993-1997)
04-08-09 05:05 PM
sunrisetrd
Performance & Maintenance
11-20-08 08:57 PM
slappy96
07-24-08 03:23 PM
tuninghaus
09-23-07 09:41 AM
Quick Reply: 02+ Aristo Swap w/ A340e 4AT Questions
