2002 is300 won’t crank when I turn the key,please help..
hey guys I have a 2002 is300 and when I turn the key there is power to the dash and all lights work but the car won’t crank when the key is turned,no sound at all.security light also goes out as it should when the key is put in ignition,any help will be much appreciated thank you.
Try this trick to find out if its a failing starter:
Or...
Same trick but have someone turn the KEY on CRANK posistion.
