Boost Cut Elimination Alternative
I have the JDM Aristo GTE swap with the BPU mods and I occasionally hit boost cut. I know previously everyone used the Greddy Boost Cut Controller from the MR2 (SW20) but that is terribly hard to come by now. I was searching for an alternative and came across this https://twosrus.com/catalog/product_...roducts_id=283
I was wondering if anyone knew if this would work or of any other replacements. Thanks
I went ahead and purchased it I seriously believe it will work. I contacted the company and they stated it is identical to the Greddy BCC. I also found an old diagram ( Supra BCC Install ) on installing the Greddy onto a Supra and its the same color coded wires. Once I receive I'll keep you guys posted.
So come to find out this will not work as it is only 3 wires vs 4 wires needed like on the original Greddy. I did find another alternative that was actually reverse engineered from the Greddy BCC itself. SpeedForSale Boost Cut Control Device
Here are the directions. I think the other link is dead.
DIY Fix: How to Install a Greddy Boost Cut Controller (BCC) on a 2JZ-GTE with VVT-i (Lexus GS300/Toyota Aristo)
