Vacuum hose size suggestion
As I piece together my NA-T setup I am taking care of all the little odds and ends now. I am looking into some nice strong silicone vacuum hoses for the wastegate and bov routing. However they come in several diameters. 1/8, 5/16, 1/4, etc, and Turbosmart sells there's in mm. 3mm, 4mm, 5mm, etc. Anyone know the "go to" vacuum line size? If there is such a thing? I don't know if there are any different effects on things by having too large or small a diameter. Some info suggests making the lines short as possible for better response, particularly with a mbc (boost controller). I'd assume diameter must have an effect then too.
After reading across many forums I have determined 1/4, 6mm, -4an (which are all the same size in different kinds of measurements) to be the right size. This is what the chevy LS guys are using, honda junkies, and DSMers.
I recently purchased some silicone vac hoses on eBay these are the spec they provided: All are inner diameter, hope this is what you are looking for.
5/32=4MM
3/8=10MM
15/32=12MM
1/8=3MM
1/4=6MM
6/16=8MM
3/16=5MM
5/32=4MM
3/8=10MM
15/32=12MM
1/8=3MM
1/4=6MM
6/16=8MM
3/16=5MM
TrueGS300 (07-24-19)
Was your kit purchased used? Because those items should have been included, and you ought to contact CX Racing if you bought a new kit and they were missing.
