Help. GTE swap no start.
Old 01-26-20 | 06:59 AM
MMett's Avatar
MMett
Default Help. GTE swap no start.
I’ve just completed my GTE swap install and I get crank but no start. I have fuel in the return side.
My concern is the ECU. It has the immobilizer in it but I don’t have a plug on my harness. I had a key programmed for it. Is this a reason for no start?
also, what is this plug for on the body harness side?
Old 04-20-20 | 01:30 PM
Flyinhawk's Avatar
Flyinhawk
I assume you’ve gotten it running by now but if not, maybe this will help? The immobalizer ecu kills the fuel pump and will not allow your car to run. I had this issue when bypassing the abs. Source a non immobalizer ecu if you can. Next thing would be to see if you used the jumpers from the aristo( Orange and black I believe). Lastly, I had issues with a bad fuel pump. A walbro 255 is a great replacement.
Old 04-20-20 | 03:58 PM
MMett's Avatar
MMett
I got it fixed. Ended up being a blown intercooler pipe.
Old 04-21-20 | 05:18 AM
Arussto's Avatar
Arussto
How did you overcome the immobilizer ?
Old 04-21-20 | 05:35 AM
MMett's Avatar
MMett
Sorry. I had a lot happen that I didn’t explain. I got a non immobilized ecu after talking with the guy that did my key programming. I didn’t want to go through the hassle of making that setup work. Then I got it running and it died. Because I blew an intercooler hose.
Old 04-21-20 | 07:06 AM
Flyinhawk's Avatar
Flyinhawk
Glad to hear you got it running. The immobalizer ecu are a pain. Makes things difficult.
ogtony19
Performance & Maintenance
03-20-12 08:56 PM
Jdm381sc
North Texas Lexus Club
06-15-11 09:12 AM
SC904
08-13-07 10:42 PM
silent1pro
12-15-06 04:06 PM
