Aftermarket Steering Wheel
Has anyone replaced the OEM steering wheel with an aftermarket one like NRG, Momo, or other ones like those. I just want to see if anyone has, I'm thinking about it but there are buttons on the OEM one that I need like after an oil change to go to the settings, or just to change things on the dashboard.
Thank you guys for the comments I'll check out the steering wheels that come with the carbon fiber.
Same question too but in case you didn't see it, did you take all the buttons and wires off the OEM wheel and transfer it over? Or did it come with the buttons and wires already and all you had to do was install it?
Did your steering wheel line up correctly in the grooves when you put it on? I centered my wheels and when i put on the new one, it was off by like 10 degrees.
I tried getting an alignment done, but it didnt fix it. I read up that you may have to adjust the tie rods to fix the issue.
I also bought mine from Elvin
Received 1,738 Likes
If it's off 10 degrees, then remove it and move it one spline towards the center from the direction it's off.
If they couldn't fix it with an alignment, then they didn't do the alignment properly...I hate the say it.
How’s the longevity on Elvin’s products? I heard some people had issues with other CF steering wheels delaminating over time.
Farizzl3 (05-14-20)
From the looks of the Elvin wheel it appears he is modding a stock wheel...therefore it should fit back exactly as the your original.
Unfortunately the papers shown the alignment was dead centered and i've actually taken it to about 3 places now and noone is able to fix it.
I know for sure i centered the wheels and put the steering wheel on as close to center as the notches would allow.
lvfstde
08-29-21 03:12 PM
Lutkis
05-01-20 02:21 PM
