200t Road to Stage 2 plus
Hello all!
On the track to a little performance and waking up this little IS200t to have just little bit more power.
Purchased TTI Stage 2 Plus w/ TCU.
Downpipe, mid pipe and axle back.
So far received the downpipe.
Titanium wrapped to minimize heat in the engine compartment.
Waiting on the rest of the exhaust coming tomorrow.
Already have the tune from TTI Motorsports, right now just running the Stage 1 w/TCU and as soon as the exhaust in will be writing the Stage 2 plus to the ECU.
MsalIS3 (01-24-21)
MsalIS3 (01-24-21)
Received 1,738 Likes
Baller!!!!
Thanks,
Gonna need resonators, way too loud, It's full exhaust from turbo to tips. Down pipe with the o2 bung threw a code. Now need to work that out. Will be flashing the ECU with a Stage 2 Plus.
Do you know what the code is yet? Not uncommon for this to happen. The tune may eliminate the code by simply..well...eliminating the code.
If not, it's likely a O2 ranger code, and an extender on the bung should fix it.
Clearly not your first rodeo with this.
That is already in there and still pulled a code, I think it's the O2 cause the car warmed up then gave it.
I have a different bung that has little cat in at an angle, might put that one on and see. But first need to get the code.
yep P0420 (Catalyst System Efficiency Below Threshold) I'll throw the Stage 2 Plus tune in it and if I still get the code I'll go ahead and put this bung in there (see Below)
You may not even need either extender...unless it was part of the installation kit.
