Question on TC stall speed
Guest
Posts: n/a
For all you TC gurus out there....Is 3000 too high a stall speed for a GS400? I know most of you are using 2800 stalls. Would using a higher stall speed adversely affect the way the car runs or is the higher stall speed negligible? Engine is stock. Any help would be appreciated. Thanks.
Re: Question on TC stall speed
Re: Re: Question on TC stall speed
Originally posted by redgs4
Check the Precision Industries Site. They mention that anything over 3K is not suitable for street driving.
If I had a GS4, I would get the 2800 stall speed. It seems that people are smoking their tires with the 2800 stall speed as it is. Anything higher would probably be pointless.
3 reasons to go with 2800
Before I got my P.I. TC I did some research - in addition to a lot of general stall speed info available on the web via a Google search, there’s probably a couple of hundred posts about the subject available via the CL search. But I can summarize why I chose 2800 as follows:
1. Mo, the CEO at Swift Racing (SRT) said “For a 430 we recommend a 2800 stall and keep the stock 3.26 rear and replace the spider gears with the TRD clutch type LSD.” The same applies for a 400. That is apparently a pretty ideal setup, Mo oughta know.
2. I personally called Precision Industries and discussed my NA GS400 with a guy that was pretty knowledgeable and was told the 2800 was what I needed.
3. The vast majority of the members that already had TC’s on CL had 2800 with no problems. There are relatively few with a different stall speed.
So, my 2800 Dragon has been spinning my S-03’s for almost a year now with no problems. No check engine lights and excellent driveability.
My .20 cents worth.
My .20 cents worth.
Re: 3 reasons to go with 2800
If you go higher than 2800 on the GS400/430, your tranny is going to be hunting gears more with rpms going up and down a lot on less than wide open throttle. Not that great unless you're on a track.
sorry for asking the dumb question, but I've been hearing about auto tranny stall speed for years, and I never quite figured out what it was, would someone be kind enough to enlighten me? From what i've figured out, raising the factory stall speed somewhat helps launches on autos.
Guest
Posts: n/a
My .20 cents worth.
My .20 cents worth.
Thanks for the great info!!!
