Transmission Slow Lazy Shifting
I posted this in the regular threads but should have been here:
Maybe its always been this way and Im just now paying attention--when the trans upshifts its not a quick sharp shift to the next gear but rather a slow rollover to he next gear taking a sec or 2.
Still drives normal and no slipping. Maybe its just age, old design, and 214,000 miles.
Please advise!
Please advise!
Please advise!
Please advise!
https://www.clublexus.com/how-tos/a/...our-ecu-363500
Have you tried resetting the ECU, and ECT? I'd give it a try to see if shifts any better afterwards. Fuse method is easier for this.
Please advise!
Please advise!
Have you changed your transmission fluid? It will be squid ink black and smell like burnt metallic juice if you've never changed it.
The way to refill the tranny is, car level and off the ground, car is running and in P so the transmission is actually circulating fluid. You add fluid while it's circulating until drain plug leaks then you stop. You go plug the drain plug up. Refill a little bit more say 200ml. Then you go back to drain plug while car is at operating temp, on and in Park. Let it out until it trickles then tighten. That is the correct level for your transmission.
Full transmission fluid change it is just the above and adding fluid until what comes out is no more black but clear pink, this will use many bottles ( I used Penrite ATF LV (WS compatible)) . But you will shift like you have a CVT
Last edited by Dealarr; 02-08-21 at 12:05 PM. Reason: For full transmission fluid change:
If they took off the gasket, they would have taken off the pan. That means the car was off. If they just refilled till the drain plug leaks while the car is OFF, you will be short of fluid that is why your trans is not shifting properly. You can check by lifting up the car on level ground(always use jack stands, and use spirit level on underside of tranny box to get level) and make sure its level while the car reach operating temp, and unscrew the drain plug off very slowly, and if liquid seeps out (with screw still in hole but not in thread) then immediately tighten it back ( Use your hand with thick dish washing gloves, don't use power/air tools, might cut threads). If there is no leak then you are short of fluid so they did not refill your tranny properly.
That was what I was trying to get you to avoid, Ive had dodgy dealer's pulled off sensor switches on my oil level near the drain pain, numerous things dealership/dealers mess with. Do you not have any other mechanics you trust or friends that are mechanics if you rather not do it yourself?
FWIW: When checking overflow temp of fluid the book says 100°F Trans temp not full operating temp. At full operating temp would leave the fluid level too low which would be bad. Fluid expands with heat and 15min of operation consistently places mine in the 160 180° range.
I'd suggest an OBD Bluetooth reader and OBD Fusion app with Toyota PID add on pack and you can monitor the temp with your Smartypants phone...
As can be seen here, even on a cold day the trans gets to engine temp pretty quick.
Is that a reality possible to visualise? Or do you believe every big company is naive, hardworking, and honest. We'd be in a different world by then. Do you work for Lexus brother?
No need to make it personal. I'm saying, the documented literature says 100°F +/-10. If someone does this on an At Temp Trans, it will be low! So, the advice given will have dire consequences.
6 years rebuilding transmissions at an Indy. Nothing to do with Lexus other than follow the procedure or burn up your transmission.
Recap - your advice is wrong!
The reason why i dont go by that book is because yes, it is lower than operating temperature, which means by normal operating temperature, the liquid would have expanded more meaning it is more pressurised now. Basically meaning "more" fluid. If the time we spend in the car are mostly in the operating temperature area, wouldn't then we be always a little over pressured? That is why i leak it at operating temp, because that is the time where the car is spent driving most so there are no increased pressure.
I took my car today to Tustin Toyota. The tech said the trans fluid level is ok, but found code P0761--trans solenoid C. I called a few trans shops some say just replace the solenoid or valve body, one place tried to upsell me a new trans for $4000 I said F that!
Either way Im seeing an expensive repair!
Yesterday got my car back from my master tech friend he did a cash side job for me put in used trans 78k miles $800 for trans, $400 install--new trans is great no more slipping, car has new life!!!
primavera (02-12-21)
