Has ANYONE had ANY Problems w/ THE SRT INTAKE & ECU for GSS400 ???
I have my srt intake...but want to ask a few questions before installing. Anyone had Any problems at all?
no problems at all when i did have mine for all of 1 week.. the install itself is a breeze , just make sure to identify your wires then splice and solder away , make sure vacum lines connect properly and most of all make sure MAF sensor is pointed towards the filter or you will have issues .
on a second note , dont get your hopes up to high , it will not transform your ride into a instant drag racer by a long shot and be prepared for a tremendous amount of noise esp at WOT, there will be some small gains only in mid to high end and SOME being the operative word
good luck to you
good luck to you
hmm...so if i add exhaust....with the srt...will that be the best way to get more hp? also, how can SRT claim that it gives a 30 hp boost w/ their intake? isnt that false advertising?
Forum Administrator
![](https://www.clublexus.com/forums/images/ranks/rank-admin2.gif)
Originally posted by lexforlife
korean
if you use the search function you will find countless threads about the srt thing.. no one has been able to duplicate their numbers or even come close to whats claimed ,,period....
korean
I personally don't have a 'before' dyno of my car prior to putting on the intake, but I did one before/after upgrading to the race ECU and it added ~5hp.
I have had no problems with mine and I've had it on for about three years now. I DO have the check engine light popped on my car (without ramifications), but I suspect that is due to my TC.
the check engine lite...yea that usually means the oxygen sensors...hmmm...have you had it checked out? i am still undecided. I have the srt intake sitting here next to me...its beggn me to put it in...im just not sure if i want to yet.
Forum Administrator
Originally posted by bitkahuna
Dave - Your light is permanently on? How do you think the TC would cause this? I would think intake more (not SRT specifically) because of how finnicky OBDII sensors have to be. Could even be a dirty filter???
Paul, I think it is likely the TC based on a few old posts I read. One specifically I can't find from Mean Gene who had the same problem (think it was in the old SRT forum that was removed), but is mentioned in these I linked below. I had the intake/ECU, TC, exhaust and borla/eibach suspension done all at the same time, so I can't isolate the culprit.
https://www.clublexus.com/forums/sho...t=check+engine
https://www.clublexus.com/forums/sho...t=engine+light
Koreanpers. If you don't mind your car being louder (the intake is pretty loud with a kind of growl/whistle sound that I personally like), put it on. If you don't like it after a few weeks, take it off and sell it.
dave
again i specifically stated MY EXP with the setup and what i used to guage performance .. setting a car up with hood open and hugh fan blowing on it does not pass with me for a intake
i would like to see real world driving sit meaning hood closed and no real huge fan blowing on it ..
i using a timer and marking distanace before and after tells the tale for "me"
thats all i have to say
Forum Administrator
dave
dave
I must disagree with the non-scientific seat of the pants / 'timer' method you tout, especially when you can easily take the same car in like conditions and get documented repeatable HP and torque ratings on a dyno (or even on a quarter mile track) for a real comparison. Tweak the car and find out what increases the changes you made did to it. That's what dyno testing and tuning is all about. Clicking a stopwatch yourself while driving is a terribly inefficient and inaccurate way to test. Do you even use a G-Tech? Let's see the exact numbers and details about the conditions each time you've tested using the stopwatch including RPM and MPH you were driving, temperature, humidity, etc?
BTW, most of my dynos have been done without a fan for one reason or another. The fan pretty much simulates the wind blowing on your radiator at highway speeds, so it's really not that much of a difference. See pictures below of my car on the dyno at SRT after getting my race ECU put in. Note there is NO FAN and it was a hot summer day. So much for your theory on the fan there...
![](https://www.clublexus.com/gallery/data/501/124LockeddownontheDynoatSRT-med.jpg)
The only dyno I've done with a fan was at a SE meet dyno event a couple of years ago. Note how huge that fan is sitting in front of Dr Ricks GS in this short clip
![Roll Eyes (Sarcastic)](https://www.clublexus.com/forums/images/smilies/rolleyes.gif)
All I'm trying to do in responding here is to clear up inaccurate information in statements you make such as "no one has been able to duplicate their numbers or even come close to whats claimed ,,period...." . I've repeatedly shown you where some people have. Let's face it, dynos are an accepted real world standard of testing HP and TQ changes, and the seat of your pants are not
Don't get me wrong, I'm not going to sit here and make any type of claim that everyone is going to see a 30 RWHP gain in their car as advertised - every car is different and I think that claim is way too high. I personally did see an improvement in mid and high performance with my own GS when I put the intake on three years ago, and again when I upgraded the ECU version to the new Race ECU that now comes standard. Some members have also noticed a loss in power at low RPMs with the intake installed, too.
All I'm trying to do here is alleviate the bias you sometimes seem to put in the wording of your posts. I'd like for our members to hear about options for modifications with a little more basis in fact. Subjective observations are certainly always welcome here too, just please don't try to make them sound like there are no other opinions that matter.
dave
i digress , i will respectfully withdraw my own findings based on "the seat of my pants " theory based on your opinion that it does not hold water . (i have only been racing imports for a few years so i guess seat of the pants does not fall into the real world category)
seeing that some may see my opinions as being biased , again i withdraw any further inputs about this topic and will allow others to be (dave excuse the comment , no bad intentions here) whipped into the srt world..
Dyno numbers are one thing , many variables affect the numbers , driving in the streets pinpointing exact distances and using a stop watch to some degree i guess accounts for nothing to the pros here and by the way dave , next dyno run , how about shutting the hood completely for i know no one who drives their gs with a wide open hood in the streets to aid in keeping the engine cool..and my statements never really said it was junk , but the numbers and actual feel of power was not dramatic to say the least to justify the added noise factor , thats all bro, constructive opinions here
Srt is still king and my own findings and the findings of another (who i promised would remain nameless) who is one of the most respected on the boards who in fact has already disected the ecu and has done mulitple tests with and without the units will now remain in silence
in amity , i remain
in amity , i remain
Forum Administrator
All I'm asking is a wee bit more objectivity to keep from misleading new members with over-the-top opinions. Consider that others might have experience and details that are different than yours. BTW I've been racing imports and domestics for the exact same number of years you have if your birthdate is correct.
Regardless, I noticed yesterday that KoreanPers was selling his intake in the classifieds so our discussion here is mute.
PS thanks for the wording change.
Yep, i decided to sell it...and not even worry about it anymore. I will just upgrade the suspension w/ trd sways, upgrade the stereo (when i have saved up enough money for the install), and buy rims
My car is fast enough
