2016 IS300 Fsport air intake question
1st Gear
Hi everyone,
I was trying to buy a K&N filter for my stock air intake. Unfortunately, they don't sell it or make it for my IS300.
I was told that only the IS350 has a K&N filter available. I asked them if I can take the 350 airfilter of K&N, they said no. That the intake for 350 and 300 is completely different setup/unit.
My question for you is. Am I able to install a 350 intake on my IS300 or should I go aftermarket intake?
Also, is an IS350 air intake the same or different from the IS300 air intake?
Thank you
Thank you
The AWD IS300 has the same V6 as the IS350.
The RWD IS300 have the turbocharged 4 cylinder and the intakes are different.
So the answer is, it depends which one you have.
If you have an IS300 AWD and are just looking for a drop-in filter, I'd recommend either of these:
- F-Sport "Performance" Filter
- AEM Dry Flow Filter
