2AR-FSE into IS250 IS300H
Hi,
has anybody consider that?
UK IS250 is quite cheap I have on done the 3GR-FSE swap and its working fine do you think that 2AR-FSE would be feasible?
Engine + Transmission and ECU would be provided is that compatible or hardly manageable?
Is Differential compatible?
10th Gear
I wish there was a market behind this, even for a 1st gen IS300. The MR2 guys are making lots of power with the 2arfe NA or Turbo.
If it's anything like the 2ar-fe, it checks off everything from a desirable list. It makes great power, has lots of availability (2arfse was limited on just the IS300H as you mentioned though), is lightweight, reliable, and insanely good on fuel.
