2000 gs300 Po125 code and overheating at idle
1st Gear
So I’ve been gettin the p0125 code for a while now, and I don’t know what else to do I’ve replaced the thermostat, temp sensor and the radiator is only 6 months old, also recently it’s been overheating at an idle making the coolant in the reservoir boil and leak out.
any advice on next steps to take?
...check the radiator cap gasket if good I would also test for exhaust gases in your coolant, with a block tester like .
good luck
good luck
jiggahwh0
09-02-24 02:03 AM
