interior photochop
okay..this may be a bit hard to do..im usually pretty decent in photoshop, but i couldnt quite figure out how to do this, or at least make it as nice as i like it..but here's a drawing of how i would like it to look, and if you would like a clearer picture, i will go ahead and scan it if you wanted, because this was just done by a camera phone:
![](http://i20.tinypic.com/123y42v.jpg)
this is for the interior of an sc300..the center console..im planning on putting a computer in there. so heres what will be done, i will be taking out the stock climate control and replacing it with the climate control from a 93 es300..the screen will be a lilliput 619gl, and where the cupholder usually goes, will be a 4-port usb hub. where the stock temp **** is, will be an aftermarket griffin powermate **** to control volume and such for my computer. but instead of the aluminum color, i would like that blackened out to maybe a black aluminum. around the trim i would like it to be a burlwood look. the screen would also be inset a bit, not sure the exact measure, but maybe somewhat similar to the drawing. in case you dont like the pictures i provide you, i could also provide you with the information needed to find the right picture you need. thanks for any help in advance!
![](http://i20.tinypic.com/28218pt.jpg)
![](http://i21.tinypic.com/121tngn.jpg)
lilliput 619gl in black
![](http://i22.tinypic.com/2dlp0no.jpg)
4 port usb hub..i dont think what brand matters, just as long as there are 4 usb ports all vertical
![](http://i20.tinypic.com/x2uvrt.jpg)
griffin powermate ****...can be found on store.mp3car.com, or maybe a google search
![](http://i20.tinypic.com/153bbpt.jpg)
dark burlwood
![](http://i21.tinypic.com/2vsgqpz.jpg)
![](http://i23.tinypic.com/20ubvo5.jpg)
basically just an sc300 center console..so any question? hit me up if you do and thanks again!
dark burlwood
![pnyboy27 is offline](https://www.clublexus.com/forums/images/statusicon/user_offline.gif)
and oh yea..down the center will remain black
heres an updated drawing of what i want to do, plus its clearer..i finally scanned it..haha
![](http://i22.tinypic.com/qyahhs.jpg)
