Unique chop needed, seize any other experienced guys help me out!
alright what i'm looking for stems from what the dealership i used to work for did to lincolns.
I need, maserati portholes like the ones on this car's fenders:
On the fender of a black 2gs. Use this for an example if you need it:
What i'm looking for:
3 in a row along the higher side of the fender (offset towards door)
3 in a row across the higher side of the fender (more spread out)
2 in a row along the higher side of the fender closer to the door
and whatever else you think looks good, play around with it! I'm considering doing this to my car.
well number one, you didn't resize them to actual size and the lighting between the portholes and the car is not corrected. These would not be stick on portholes; these would be authentic maserati pieces with the fender actually cut and these put in it's place.
looking at the fender shape they might have to go below that crease since that's the flat part...which would look a lot better.
