Has anyone had trouble getting the Enform remote to work?
#32
What you do is get the Carista Pro App, and a Bluetooth ODBII connector and make all the changes you want. I can even roll down the windows with the KeyFob now as well as remote start the car. Sweet .
![Woohoo](https://www.clublexus.com/forums/images/smilies/woohoo.gif)
#34
Yes that will work, but only if it has been programmed by the dealer first. If yours works from the start the Dealer already did it for you as it is a Dealer Only programming option. Check my sheet as it lists all the things you can change and the items that only the dealer can do.
#35
Starting the car with FOB doesn't help me as I putt out on #18. The remote app allows the RC to cool down while I wrap up my round. In this Arizona heat it's a great solution.
#36
The fob is a bit faster if you are close, but if you are that close to start with, what's the point of starting it remotely, as it stops when you touch the door handle a minute later? The only use I can think of for starting it with the fob is when the car is out in the cold (heat) at the curb and you are close enough inside the house to fire it up with the fob. Other than that, remote starting from a great distance is a wonderful (what we used to call nifty) feature. Starting your car from the 18th green (or the baggage claim) is just plain great fun.
#37
#38
So when remote starting, theres no way to keep the car running? If you touch the door handle it shuts off? I installed remote start on my truck and old Integra and the car would shut off only when you press the brake without the key in the ignition. Please tell me this isnt so.
#42
#45
It prevents this type of accident, https://youtu.be/cQkbrFcXSqI
