LED Door courtesy lights & Footwell Lights Installed
What he said, but instead I used a small plastic interior trim removal piece from Harbor Freight Tools.
Me too, but I wanted to make sure I didn't damage anything, again. Let's just say I have personal experience using a small screwdriver as a pry tool, and having it cost me $100 to replace something that was nicked by the screwdriver. I learned my lesson. Use the proper tool for the job.
I had trouble also as my fingers kept slipping off the bulb. What I used was a rubber exam glove. The kind you see at the doctor's office or can get at the auto parts store. Or just use some carb/brake cleaner on your fingers to get rid of all oil.
Here are some pictures for the people who like to visually see things (like me )
This is the trunk light removed. Lift the black cover off and replace bulb.
The arrow on the right shows where to pry the light off. This is the puddle lights on the doors.
This was tricky for me. Use a small screw driver and lift that inner tab, then lift the gray cover off.
Do you guys have a recommendation for the trunk light? I popped these in
Works well for the door and footwell but the trunk seems to dim/dark with these.
Amazon.com: Zone Tech 10x 194 168 2825 5-smd White High Power SUPER BRIGHT LED Car Lights Bulb: Automotive
I have a bunch of worthless 194 LED bulbs so hopefully my mistake will help you find the correct bulb.
http://m.ebay.com/itm/201331107137?_mwBanner=1
These r the ones i ordered and installed. They work great. Pic below. Left is before. Right is after. You can see the major difference
