DIY: How to replace taillight bulbs
Old 04-02-15, 03:00 PM
jowsleyyy
jowsleyyy's Avatar
Default DIY: How to replace taillight bulbs
This is for the people who want to either swap their turn signal or reverse light to LED's, or replace a burnt out bulb.
This is my first DIY I've done so if I missed any steps or you have any questions let me know and I'll help ya.
Originally Posted by GearHead69
If you don't want to use a load resistor then make sure the 921/T15 bulbs are CANbus compliant. What that means is a load resistor is built-in the housing so a load resistor is not needed.
CANbus (Error free) High Power 921 T15 White LED Bulbs are what you are going to search for. I just ordered a pair of high wattage (15 watts with 800 lumens of visibility) off of eBay.
1. Remove the two clips on the inner lining of the truck. They pop off with a flat head.
2. Remove the two hex bolts that keep the tail light in place. I believe I used a 7/16.
2a. Remove the housing by pulling straight towards you. You gotta wiggle it a bit and it'l come out.
3. Remove the bulb you want and plug in the new one. If you want to install an LED with a resistor continue below.
4. Unscrew the **** that holds your grocery bag liner. MAKE SURE YOU REMOVE THE SCREW BEHIND IT. Otherwise it may drop down and be lost forever.
The top one pops out with some prying. Here's an image of what the screw looks like. You pry it out with a flat head.
5. Life up the liner so you can pry open the side of the trunk.
6. Use a flat head to remove the grommet so you can thread another wire back there. This is where I threaded my resistor.
7. I put a command strip on the resistor and stuck it inside on the body of the car so it won't rattle.
7a. Test out the connections (pump brake lights, put hazard lights on, use the turn signals to make sure there is no hyper-flash etc...
8. Plug everything back in place and you're done! Make sure to slide this in when you are putting your tail lights back on.
OEM Halogen bulb installed
To access the front bulbs you pop off two tabs in the front rear wheel with a flat head. Turn 90 degress one way and they pop off. Then you reach in there to find a long gray flat tab. Turn this to the right and the bulb comes out. Simple replace and you're good to go. (sorry no pictures on this one, I had to remove my wheel to get the V3 Tritons installed and had too dirty hands to take any)
V3 Triton bulb installed
OEM Halogen Reverse light installed
To access the reverse lights there are two tabs on the inside of the trunk. Pop off both tabs and pull the liner down. Remove bulb and replace. Very easy only takes 5 minutes both sides.
LED Reverse light installed
Vled V3 Triton vs OEM bulbs Rear
Vled V3 Triton vs OEM bulbs Front
VLED Reverse bulb vs OEM
Old 04-02-15, 03:08 PM
GearHead69
GearHead69's Avatar
Good write up, and thanks as it will come in handy when switching to LED bulbs.
Old 04-04-15, 10:55 AM
ngpFSport
ngpFSport's Avatar
Guys,
I attempted to swap out by back-up bulbs to brighter LED today, following these instructions and figured out a few things.
1st - you don't need to touch any of the trunk interior just to change bulbs. You just pop off these two little covers and remove the 2 hex bolts with a 10mm socket. Wiggle the whole light housing backwards and it will pop off.
2nd - has anyone actually changed the back-up bulbs on the RC? I believe that other than the turn signal bulb, everything else is built in LED.
raerae1616 (06-17-19)
Old 04-04-15, 03:18 PM
jowsleyyy
jowsleyyy's Avatar
Originally Posted by ngpFSport
Guys,
1st-I agree there is no need to removed any of the trunk interior if you are swapping out the bulbs or replacing the bulbs without a resistor. If you do have a resistor I would encourage you to thread the resistor through and keep it inside to further protect it from the elements. the Vled V3 Tritons did come with a resistor, so I decided to keep it inside the trunk.
2nd-If you check here, Sylvania shows that the back up, turn signals, interior door light, stepwell light, parking light, and trunk lights are regular bulbs (since they show a part #). The rest are LED since they show that as their part numbers. This is just my assumption though.
Old 04-06-15, 08:49 AM
mfresh21
mfresh21's Avatar
Default Reverse lights
Here are some pics of my rc fsport with my reverse lights changed
Old 04-06-15, 09:30 AM
Zfrog
Zfrog's Avatar
these come with halogen bulbs there?
Old 04-06-15, 09:36 AM
jowsleyyy
jowsleyyy's Avatar
Looks really nice! Which bulbs did you choose?
Yes turn signals and reverse lights are halogen bulbs.
Old 04-06-15, 12:40 PM
GearHead69
GearHead69's Avatar
Old 04-06-15, 02:04 PM
jowsleyyy
jowsleyyy's Avatar
Updated the DIY to the top to share the information. Thanks!
Old 04-06-15, 02:18 PM
GearHead69
GearHead69's Avatar
No problem. Glad to help.
Old 04-08-15, 04:15 PM
jowsleyyy
jowsleyyy's Avatar
Updated with some simple instructions to replace the front turn signal bulbs and the reverse light bulbs
Old 04-08-15, 04:36 PM
GearHead69
GearHead69's Avatar
Thanks as my Reverse and Rear Turn signal bulbs are coming in this week.
Old 04-10-15, 08:19 AM
GearHead69
GearHead69's Avatar
Just got my CANbus LED reverse lights in and here is a pic.
On the left is the new LED, and on the Right is the old bulb. What a difference.
New CANbus LED reverse light on left, OEM on Right. What a difference
Old 05-24-16, 07:52 PM
happy1977
happy1977's Avatar
Does it have to be a Canbus error free for the reverse tail light?
Was thinking of using this since this is the same light that I used for our RX 350 back up light
http://www.ebay.com/itm/121988119702?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Old 06-17-16, 11:20 AM
Dimitri
Dimitri's Avatar
great write up !!
Quick Reply: DIY: How to replace taillight bulbs
