Aftermarket Wheel Question
So this goes out to the guys that have aftermarket wheels. I currently have aftermarket wheels and went to try and change my set up to a more aggressive stance and these suckers just wouldn't fit. How is everyone throwing 10.5' wheels in the back without rubbing? I am lowered so take that into account. Here are the specs I am looking at
Front: Tire (245/35/20) 10" wheel +40 Offset. This fits fine without jeopardizing the fender but they did have to add a 5mm spacer just to clear the brake. Wouldnt fit on it without the spacer with this offset.
(Current front setup is 9" wheel with +35 Offset)
My main question is the rear.....
Rear: Tire (275/30/20) 10.5" wheel +30 Offset. Took a few pictures. The car is lifted on the lift but when it is sitting there is no fender gap front or rear. Maybe fit a pinky in it.
(Current rear setup is 10" wheel with +40 offset)
What am I doing wrong?
Current Setup
Current Setup
In the rear, you're sticking out 16mm more than your current setup. 20x10.5 should be +45. See this thread:
https://www.clublexus.com/forums/rc-...eels-drop.html
You should use this site for calculating offsets:
http://www.1010tires.com/Tools/Wheel-Offset-Calculator
You just need a smaller tire. 265/30 from a toyo or Falken. 255/30 from everything else. Either that or get camber kit so you can dial in camber.
I run 20x10.5 +15 255/30 in the rear. I drive on air very low with no rubbing whatsoever. It's a mild stretch.
275/30 tire and +30 is probably the limit for these cars. It was the limit on a few of my previous car before you needed to start trimming bumper brackets and or camber, etc.
