See simple reverse light LED change
This is just something we did in like 10 minutes. It's really a simple mod of changing the reverse light to LED. First steps are shown below.
We used a plastic clip remover to take the clips out as shown, then just simply unplugged the original bulb and replaced them with the SMD LED white bulb.
Here are some before pictures:
Here are the results:
Top pic is before, bottom is after:
Night time:
That is all. Just wanted to share this quick and easy mod.
Night time:
I also did the same with my ISF, it changes the look of the car A LOT...when in reverse.. haha!
Make sure to buy some quality LED's so you do not have to constantly change out burnt bulbs!
-Josh (jlee@modinjapan.com)
I tried LED Blinkers before (on another car) but they did not have enough load to them being LEDs that the car ended up flashing faster than normal. Is that the case on the RC?
https://www.clublexus.com/forums/rc-...ml#post8983357
This is from the sticky above. In that thread has posted some part numbers etc
