Glare with gauge cluster
Old 08-14-15, 10:11 AM
walkedu
walkedu's Avatar
Default Glare with gauge cluster
Not sure if anyone else has experienced this but on sunny days when looking at my gauge cluster I find it hard to read since the glare is pretty harsh. I tried adjusting the lighting on it but it seems to be the actually glass/plastic that is causing the problem. Has anyone tried like an anti-glare coating on it?
Old 08-14-15, 02:01 PM
stevez2
stevez2's Avatar
have noted the same. seems like the led lighting of the dash does not adjust bright enough
Old 08-14-15, 02:27 PM
Baopee
Baopee's Avatar
i am having the same problem, the plastic cover is the problem.
Old 08-14-15, 02:42 PM
walkedu
walkedu's Avatar
Ya that is what I'm thinking also. It gets real irritating since I cant see my gauge cluster, esp driving on the freeway.
Old 08-15-15, 06:06 AM
Fsportf
Fsportf's Avatar
Window tints might solve that problem for u
Old 08-15-15, 08:53 AM
walkedu
walkedu's Avatar
I have 25% all around still no luck, just not on the windshield which where all the sun comes from. Kind of a pain to tint that part esp at night time.
Old 08-15-15, 09:22 AM
Baopee
Baopee's Avatar
That might be the only solution. To make the mater worse. I have 2014 is350 F,I can barely see anything at all during the afternoon drive home.
Old 08-15-15, 10:34 AM
GearHead69
GearHead69's Avatar
Yep, I'm having the same issue. My windows are tinted, and depending on the sunlight angle it is almost impossible to read the gauges at certain times of the day. I think it has to do with the angle of the lens, which we can't fix.
Old 08-17-15, 03:46 PM
BossHu
BossHu's Avatar
its a bit unconventional and possibly a bit of a long shot... anyone want to try using glare control window film on the instrument cluster?
Old 08-18-15, 06:59 AM
Baopee
Baopee's Avatar
I just realized it while driving home yesterday, the glare is not caused by direct sun light, it is caused by sun light being reflected from steering column.
Old 08-18-15, 07:04 AM
walkedu
walkedu's Avatar
Ya but that glare is essentially getting reflected into the Lens
Old 08-18-15, 08:16 AM
rwickens
rwickens's Avatar
Is this an F-Sport problem, mine is not an F-Sport and I do not have the issues you are mentioning?
Old 08-18-15, 08:25 AM
Baopee
Baopee's Avatar
So instead of getting film on lens, is there anything that can be put on steering column to reduce the light being reflected?
Old 08-18-15, 09:49 AM
BossHu
BossHu's Avatar
probably some kind of tape of some sort? or wipe off that armorall (if any)?
Old 08-18-15, 09:54 AM
walkedu
walkedu's Avatar
Honestly I wouldn't know if putting any matte material on the steering column would help. I just tried putting like a towel on the steering column and it still gets reflected on the lens. So basically you would have to put some anti glare film on the gauge glass / plastic. Not sure if they make like an anti glare film. I would have to ask my tint / wrap shop.
Quick Reply: Glare with gauge cluster
