New Owner Helpful Hints
Setting the Auto-blinker rate:
https://www.clublexus.com/forums/rc-...o-blinker.html
Owner's Manual Available for download from Lexus:
https://www.clublexus.com/forums/rc-...rom-lexus.html
Remote Starting the car with the Key Fob:
https://www.clublexus.com/forums/rc-...h-key-fob.html
What you and the Dealer can customize with the Vehicle Settings:
https://www.clublexus.com/forums/rc-...lanations.html
Before the remote start with the Key Fob will work you need to make sure Lexus Enform Remote is setup and working on your car and smart phone. After that it should work.
The cadence of the lock button pushes is pretty important, press the lock button three (3) times
quite quickly and hold the final 3rd press. Watch for the various marker lights to begin flashing
and you can release the lock button. The car will start within 5 seconds. Note: whether you use
the fob ('80 range/5 second response) or the App ( infinite range/30 second response) the car will
shut off when you touch/unlock and open the door.
Thanks MCOMER for pointing out that the sequence and timing of pushing the buttons is critical to make it work correctly. Range also plays an important part of it as the best I could do was about 100 feet, but most of the time it is about 75 ft. or less.
Now if you really want a cool feature you can use the Key Fob to open the sun roof and windows, but you need the CARISTA Pro App or get the dealer to program it for you. This is one of those things that is on the list of customizations for your vehicle.
