Lexus RC350 Fog Lights Question.
Hi All,
I just purchase a brand new RC350 base model, I didn't realized that the base model did not come with fog lights. Can anyone suggest where to buy online for a pair of fog lights and model?
If anyone has installed a after market fog lights, could you attached pic? Thank you in advance.
Are you looking for functionality or style? Nothing will work style wise unless you modify the grill. Functionally anything you put on the nose of the car will look like hell.
I'm curious if anyone has installed one for functionality rather than design, I do want to see what it look like before investing time.
Hi All,
Get something retrofitted in into your stock lamps or just get RCF one....not sure, but I assume they have fog lights built in and fit our cars perfectly. I think this because of the shape and the fact that I also didn't notice any fogs on that bumper either.
I removed the fogs from my F-sport and have the grille pieces and fog lamp assemblies available if anyone is interested in retro fitting, you will have to come up with wiring and a switch but any automotive wiring person would be able to handle this, just send me an email:
enterprisesofgage@gmail.com
VindiCated (07-23-20)
Looks like it will be expensive. The Fogs are ~$600 each but would think you would need the following at the least.
R fog - https://www.mylparts.com/oem-parts/l...MtNWwtdjYtZ2Fz
L fog - https://www.mylparts.com/oem-parts/l...MtNWwtdjYtZ2Fz
R fog bezel - https://www.mylparts.com/oem-parts/l...Y2LWdhcw%3D%3D
L fog bezel - https://www.mylparts.com/oem-parts/l...Y2LWdhcw%3D%3D
Thanks for the input jonmonkey and baggedRC .I would like to go OEM route and not retrofit as I'll have to make custom brackets that contour the grill shape (make it strong, hold and last).
My plan is to find these cheaper from the scrap yard from an RC that has rear end damage.
My question is; are there OEM wire harnesses (on my RC that does not have fogs) that I can plug and play the OEM fogs into? Or will I I need to cut up the OEM fog harness and rig up my own switch (location probably by the blank buttons near the ASC volume)?
Also, Its probably not as simple as getting the OEM turn signal stalk (the one with the fog switch) and replacing it either?
If by some miracle your car is pre-wired it will be a simple plug and play.
VindiCated (07-24-20)
I have the fog lights on my RC, because they came on a car that had everything else I wanted. They look cute down there in the grille, if anyone notices, but during the few times I drove through some fog, I could not tell much difference.
I say that to question whether the cost and trouble of retrofitting fog lights is worth it. Not for the utility, I would think, and I doubt if, when it comes time to selling the car, if having fog lights is going to make much of a difference.
VindiCated (07-26-20)
Hi All,
![](https://cimg1.ibsrv.net/gimg/www.clublexus.com-vbulletin/1500x2000/20200412_125105_79bb916bdca7109251454df6b35ef370d42ee1dd.jpg)
The following 3 users liked this post by Azndannyt:
