Speaker Vibration in Door Panel
Anyone have an issue on their RC where the door panel speakers cause a vibrating / buzzing noise within the door panel at certain frequencies? I'm not talking loud either. It is intermittent. If a put the slightest bit of pressure on the panel, the noise disappears. Sounds to me like the sound waves are causing a wire or something small to vibrate within the door panel. The speaker itself it fine.
Thanks!
Thanks!
Thanks!
Thanks!
I DO!!!!!!! I was wondering if anyone else had this too.... its at very low but it rattles... also my passenger door adjustment ***** for seat (moving up, back, in, out) those plastic things you push to move seat are rattling too...
I have Non ML.
PS. Sounds like mine is coming from passenger side
I have Non ML.
I have Non ML.
Just a bit annoying for a $55k car. My guess is lack of sound insulation but I'd hate to opt towards "minor surgery" and have the door panels removed and padded more as it may open up a can of worms and lead to new noises. Otherwise all else is solid and honestly impressed how quiet the cabin is overall. Again, the speakers are fine. Apparently, the "insulating" is not.
If anyone has had this fixed successfully, please post! Otherwise, I guess I can keep applying slight pressure on the door panel while I'm driving as a fix. :P
FUZCO, it is as you mentioned, not enough insulation in the door panel. I took my car in because I was scared of a issue becoming bigger. The technician stated that nothing is wrong just a lack of insulation.
compared to the new CTS, the sound insulation in the RC is awful. I also get the rattle from my speakers at certain frequencies, but I didn't have it in the warmer weather.
Hereʻs the link:
https://www.clublexus.com/forums/gs-...attle-fix.html
there is considerable vibration coming from the sunroof glass when playing music with the bass up. It's a major design flaw and is pretty terrible. Embarrassing too when you have a passenger.
Edit: forgot to mention this is in a 2016 RC300
I have it in the 2015 RC350 F-Sport with base stereo as well....
pizitz70
12-31-10 02:28 PM
