RC350: Post Your Aftermarket Wheel Fitment and Tires
Old 03-15-21, 10:55 AM
  #196
jonmonkey
jonmonkey's Avatar
I have 20x9 with 255 front tires. These rub but think they would not if I had 19" wheels. The width should not change your aspect ratio. You should be able to go to 240 without a problem.
jlt05 (03-15-21)
Old 03-15-21, 12:42 PM
  #197
Fithamoto
Fithamoto's Avatar
I bought a set of RCF rims... they are 19x9 and 19x10 (not sure of the offsets). I have 255/35/19's on the front and 285/35/19 on the rears. No rubbing issues at all in front or back. I'm actually gonna got to 265/35/19 on the fronts next. If they rub?? they will only rub on the extreme wheel turning when parking or something like that...so you won't be going fast or anything.
Old 04-26-21, 03:18 PM
  #198
mistermatt
mistermatt's Avatar
Anyone else having rubbing on the front with 20x9 rims and 255/35 tires?
Old 04-26-21, 03:55 PM
  #199
Fithamoto
Fithamoto's Avatar
How bad is your rubbing? Just in parking lots and very slow tight turns? I have heard that some of the 20's will rub depending on width. I'm gonna try to go with a 265/35/19 for my next fronts....I would like to try and try and test fit them before I buy.
Old 04-27-21, 04:34 AM
  #200
mcenteep
mcenteep's Avatar
I'm running 245/35R20 on 9J ET 35. Very minor scuff on fender liner in tight turns. Slight liner rubbing during heavy dips at the top but not show-stopping. It's bearable.
Old 05-01-21, 09:15 PM
  #201
Field110
Field110's Avatar
Default Summer wheels/tires
Square set up, Niche Vosso 19x9.5 38mm. Yokohama ADVAN APEX 245/40R19. The extra offset and wider tires seems to have reduced the amount of tramlining
mistermatt (05-04-21)
Old 05-14-21, 09:42 AM
  #202
stevolives
stevolives's Avatar
Really like this ET40 in the back, looks incredible
Old 06-08-21, 01:10 PM
  #203
RJRJ1212
RJRJ1212's Avatar
Default 2015 rc 350
Originally Posted by FR500GT
I haven't seen that wheel size with offset and tire yet so I cant say exactly how much it will stick out but you can try to reference these:
On my car I am running 19x8.5 +35 (245/40R19) and 19x10 +40 (285/35R19). The front is as wide as it can go without hitting our stupid fender liner (on the outer side of the fender). The rear with 285's is as far as it can go without rubbing or hitting on bumps. So basically I made it so I could run an aggressive setup while keeping the car functional for daily driving duty.
Another popular setup is 20x9 +32 (245/35R20) and 20x10.5 +45 (275/30R20).
With that being said, these are RC's running lowering springs and all of them are daily drivers. You can always go coil-overs which might give you a little more room but more than likely if you want to run those wheels you're going to need to run tire sizes similar to the stock 235/265's. Hope this helps.
Hey there, just about to pull the trigger on some upgrades and a total newb to this. after reading through basically this entire thread it looks like i'm going to get 19x8.5 +35 & 245/35/r19 (front), 19x9.5 +40 & 275/35/r19 (rear). It's my daily so i'm not sure about lowering springs, thought id check the fitment before buying. I was wondering if you happened to know if these specs would do well and if not, any recommendations? Thanks.
Old 10-30-21, 07:06 AM
  #204
0Jude0
0Jude0's Avatar
Default Awd
Looking to get concave wheels for my AWD. I cannot figure out what’s a good setup for 19inch wheels that won’t mess up the awd system. Could someone please tell me specs that they have tried +/- share photos.
I really can’t figure it out :/
thanks!
Old 09-01-22, 08:06 PM
  #205
LexusRC805
6th Gear
LexusRC805's Avatar
Default Variant Xenon - Satin Black
19x8.5 and 19x10 with P4s. Car is lowered on RSR Downs.
The following 4 users liked this post by LexusRC805:
blackbond (05-30-23), Gen2IS26 (09-03-22), jonmonkey (09-01-22), mcenteep (09-02-22)
Old 09-04-22, 08:28 PM
  #206
SethP
SethP's Avatar
OEM F Sport wheels. 19x8 with a 40 offset wrapped with Michelin Pilot Sport All Season 4.
mcenteep (09-05-22)
Old 09-05-22, 09:09 AM
  #207
Fithamoto
Fithamoto's Avatar
SethP,
I almost bought that same color...but it sold from out under me the day I was going to buy it. Your RC looks good!
What type of exhaust is that?
Old 09-05-22, 03:03 PM
  #208
SethP
SethP's Avatar
Originally Posted by Fithamoto
SethP,
@Fithamoto it's the Lexus F-Sport exhaust. Has a Lexus part number and can only be purchased new via the dealership and has F-Sport engravings on both sides of both tips. I made a post about it here.
Old 09-13-22, 04:57 PM
  #209
Fithamoto
Fithamoto's Avatar
Do you have a sound clip so I can hear it? Please post up if possible or send to me thru DM.
Old 09-14-22, 07:08 PM
  #210
SethP
SethP's Avatar
Some IS owners have already posted their videos, but here's mine. Nothing extreme on the revs but a different sound nonetheless.
Fithamoto (09-15-22)
Quick Reply: RC350: Post Your Aftermarket Wheel Fitment and Tires
