RC350: Post Your Aftermarket Wheel Fitment and Tires
#211
MOMO Bernina 18x9.5 square
AWD RC300 FSport
Downsized from OEM 19" FSport wheels to:
MOMO Bernina
Square setup (awd)
OEM VS. New Wheels
Girthy
Front tire clearance to strut
Front brake clearance test fitting
18x9.5, 5*114.3, +35 offset
265/40R18
Lowered on RSR Downs
No issues with brake clearance.
Just installed, will update with any rubbing issues.
MOMO Bernina
Square setup (awd)
OEM VS. New Wheels
Girthy
265/40R18
#214
Lug nuts for aftermarket wheels
I just purchased some 19” aodhan AFF7 wheels for my RC350. I’ve removed the and reinstalled the stock wheels a few times for maintenance and I noticed the lug nuts are used to center the brake rotors. What kind of lug nuts should I be looking for that will center the rotors with my aftermarket setup? I can’t seem to find any info on that. I was hoping to be able to just use the stock lug nuts but I doubt I’ll be able to do that.
#215
#220
Soneencris, do you have any issues with rubbing with this setup. I just changed out to 19" 8.5 +30 and 9.5 +38 running the stock 235/265 rubber and definitely need to bring it down some. Debating between swift springs or OEM F Sport springs and your setup seems to be the closest I can find to my rim size and offset. I would like the swift springs but worry I might rub with the 1.6" drop and the +30 offset in the front. Any advice would be greatly appreciated. Thanks.
#221
2015 rc350 rwd
Vertini RFS1.8 19" x 8.5" 30mm and 19" x 9.5" 38mm
235/40/19 front, 265/35/19 rear Toyo Proxes Sport A/S
Stock suspension for now but probably going with the OEM F Sport Springs in the near future
Sorry for the bad pictures but we've had rainy weather lately. I wanted to at least get some pictures with the new rims installed.
