Question with Check Engine Light
I just installed my Takeda Cold Air Intake, after driving it for about 30 minutes my Check Engine light came on and it said 'trac off' in the information center. When I got home I took a look and discovered that my Crank Case Hose had come off (new CAI must have slightly smaller connection point?). Now that I fixed it what would be the process of getting the Check Engine light to go off??
unless you have an OBDII scanner that can do it.
