RC350 intake suggestions
Old 03-19-18, 02:47 PM
  #31
GearHead69
GearHead69's Avatar
Originally Posted by louczar
Thanks for the answer! Do you live in a city with not much in the way of dirt roads or dusty conditions? I only ask because I live in the country and soem of the roads can be pretty dusty / dirty with all the dirt haulers around here.
Does the wet or dry filters clean equally as well as each other?
Since I live in the Phoenix metro area and live on paved roads it is not too dusty, but in the Summer months we can get several really bad dust storms that will necessitate cleaning the filter twice during the Summer monsoons.
From what I've researched the Wet filters filter better than dry. There is more maintenance with the wet filter as you have to soak them in Dawn dishwashing to get all the oil and grime off first. Then you have to let it air dry for a few hours before oiling it again, and when oiling don't put too much on as it could seep through and get on your MAF sensor.
It all depends on if you don't mind the extra steps associated with an "Wet" filter.
Old 03-20-18, 10:35 PM
  #32
Crown7
Crown7's Avatar
Any update on the K&N?
Old 05-11-18, 10:50 AM
  #33
dim13
dim13's Avatar
Default Takeda Intake
I just installed the Takeda dry filter intake in my 2015 rc 350. The crank case hose is not staying put, however, even after installing screw on clamps.
I found a heater hose that I could retrofit to replace the crank case hose with. Would this be okay to use? I have received mixed information on this topic, as some people are saying the rubber on the heater hose could break down.
Thanks!
Old 06-26-19, 08:19 AM
  #34
drutyper
drutyper's Avatar
Will this fit in a 2017 RC300? I'm getting warned that this won't fit on my car since its not a 350? Can anyone confirm?
Old 06-26-19, 07:16 PM
  #35
Rudiculous
Rudiculous's Avatar
Originally Posted by oldcajun
The RC300 AWD has a detuned 3.5L V-6, the RC300 RWD is the old RC200t, just renamed.
Here it is again
Whitelex09
Performance
12
02-22-15 01:59 PM
aznoutkast
Performance
07-13-12 05:44 AM
DaNiELx626
Performance
04-26-10 06:53 AM
dotkong
Performance
10-16-08 09:51 PM
Quick Reply: RC350 intake suggestions
