What is your car's MPG?
Im sure there is some info on this somewhere but does driving it in sport + mode in manual any different than it being in normal or sport?
Does it drive any different in manual being in a different mode?
You're controlling the gears in manual mode why would it make a difference if it was in sport or sport+
Yes it drives different in manual mode as you control when it shifts to a point. The car has a built in non-self destruct mode so if you forget to shift it will automatically shift up to not destroy the engine or transmission.
In Sport or Sport+ the shifts are closer together, and more so when in Sport+. In Normal mode the manual shifts are not as fast.
Try it for yourself and you will be surprised at the difference in Sport+ and Full manual mode. I only use Full Auto when in bad traffic so I don't have to keep shifting up or down all the time.
In Normal mode it will use all 8 gears, and you can shift manually, but it then goes back to "D" after a little bit if in full Auto Mode "D". Using Full manual mode in Normal allows you to control when it shifts just like in Full Manual Mode in Sport or Sport+.
It's certainly my only real issue with the car, but it's no big deal as that's not why I bought the car. I have an AWD 350 F sport and I get 18.1-18.5 with a mix of mostly normal auto and some manual sport +
Went on a 400 mile trip this weekend where most the roads were 55 mph. Was surprised to get 29.0 mpg. Much improved over my first trip when I got 24 mpg. I have the AWD 6 speed.
I can only imagine that figure lol normal mode? A/C off? 24 is really the limit here. With A/C on, MPG drops to 22
