brand new brakes are squeeking
I recently changed out my front brake pads to ceramics since the lexus oem brake pads were giving off too much brake dust
but now my problem is that when the cars been sitting for a few hours and i drive it in the beginning it squeeks like crazy until the brakes have warmed up
does anyone know how i can fix this problem???
Which ceramic break pads did you buy? Brand and model? Also, lexus recommends you change the rotors with every brake change...but on this car that could be kinda expensive. On my old Honda and other less performance cars, I would just get new aftermarket blank rotors because they are so cheap. However, on this car I am considering getting my factory rotors cut when I eventually need to change my pads.
I've got an F-Sport - I get the occasional squeal. The dealer mentioned the pads on this vehicle will squeal occasionally at low speeds. They offered to remove my pads for a softer compound that was available but mentioned a reduction in brake performance.
You probably need to "Bed in" your brakes. Here is a link on the procedure. http://brakeperformance.com/bedding-in-rotors.php
I have no squeal, and my brakes are about 2 years old, but then when I got the car I performed the brake bedding in procedure and I haven't had an issue yet.
bought the brake pads off amazon.....read somewhere in the threads that these are pretty good for the price
i don't like the oems as there is a lot of brake dust.....after i wash my car the next day the rims are black and sometimes the dust gets on the side of the car
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Centric 105.1118 Posi-Quiet Ceramic Brake Pad with Shims - $40 for front pair
Thanks Gearhead! I'll have to try that method out and see if that helps........like i said it's only in the beginning when the car is cold, but once the brakes have warmed up it doesn't make any sound
also i only drive the car like 2-5 miles a day because work is like 10mins from where i live
I heard this from the dealer where I am located. My family owns an infinti q60 as well and its the same story....not saying I actually listen though.
