200T Tuning List
Old 04-10-17, 08:41 AM
Sheddy
Sheddy's Avatar
Originally Posted by TTITony
TTI Motorsports is proud to announce the following products and pricing list.
Stage 1 - $799.99 ECU tune with tools.
Stage 1 + TCM tune - $999.99 with tools.
Stage 2 - $949.99 ECU tune with tools.
Stage 2 + TCM tune - $1149.99 with tools.
All transactions will be done via Paypal.
The tools are necessary for the reading/writing of the tune into your ECU and can be used to revert to stock as well as for those wanting to upgrade from Stage 1 to Stage 2. For customers not wanting to keep the tools, they can return them to TTI within 7 days of installation and we will refund $200 back to your Paypal account.
All prices are subject to change without prior notice. Please email for current prices and availability of products. We reserve the right to discontinue products as necessary because of quality, durability, price or other reasons. All pricing is in US Dollar for the USA market only
Update on pricing for ECU reflash from TTI
Old 04-10-17, 09:24 AM
Isokk2017
Isokk2017's Avatar
What is that? Email me tell me more~~😁
Old 04-10-17, 10:06 AM
Sheddy
Sheddy's Avatar
It's an ECU reflash from TTI motorsports ; check out my thread for more details.
https://www.clublexus.com/forums/per...200t-tune.html
Old 04-19-17, 07:19 AM
Sheddy
Sheddy's Avatar
**UPDATE**
https://www.clublexus.com/forums/cl-...group-buy.html
Old 04-22-17, 11:19 AM
Sheddy
Sheddy's Avatar
All pulls were made on 93 oct
Modifications
OEM & Stage 1- K&N drop in filter.
Stage 2- HPS intake tube w K&N drop in filter and TTI sports catalyst down pipe.
Old 06-12-17, 07:34 AM
Sheddy
Sheddy's Avatar
Updated dyno results.
Old 07-25-17, 08:45 PM
Sheddy
Sheddy's Avatar
I have a brand new Burger Tuning piggyback for the 8AR-FTS motor with data cable (to adjust boost) up for sale on the 3rd gen IS classifieds.
Old 08-31-17, 02:35 PM
Sheddy
Sheddy's Avatar
ORANGE VIRUS TUNING
Stage 0 with TCM tune- $809.99
https://www.ovtuned.com/collections/...e-package-2015
Stage 0 tune on 91 OCT
What type of things are changed?
  • Boost Pressure - From stock 15psi to 19psi
  • Ignition timing - Ignition is modified to take maximum effective use of premium octane fuel (91,92,93, 95)
  • Air fuel - Air fuel ratios are modified to provide better power without excessive enriching in high RPM
  • Rev limiter- Rev limit can be adjusted up to 7000 RPM
  • Valve timing - Modified Camshaft valve timing to increase MPG, response, torque and top end horsepower
What are the expected gains?
  • You can expect on a 100% stock vehicle with 91 octane
  • 30-40 Horsepower / 45-60+ ft lbs (higher with 93 is possible)
Our tune eliminates mid-range throttle reduction. The stock ECU limits throttle from 2000 RPM to 4000 RPM to 30% to create a "flat" torque curve. But in reality all it creates is less power!. Our tune allows for FULL THROTTLE EVERY TIME!
Normal shipment time on remote flashing tools can vary based on our License dongle stock. Average ETA is same week as when the order is placed.
Please Note: YOU DO NOT HAVE TO REMOVE YOUR ECU FOR THIS TUNE. THIS IS A COMPLETE TUNE FOR THE ECU (ENGINE) AND TCU (TRANSMISSION)Transmission Map Tune:
  • FASTER SHIFTING - Modified shift timers
  • FASTER RESPONSE - Modified shift pressure
  • NO SHIFT LAG - Modified shift delay timer
  • TORQUE OUTPUT CONTROL - No power loss through shifting and more
Old 10-03-17, 08:29 PM
Sheddy
Sheddy's Avatar
PPE engineering has informed me that they have received more parts to start mass production of their down pipes.
You can order them here.
http://www.ppeengineering-onlinestor...9200T01-SS.htm
Old 10-04-17, 10:19 AM
Meraki Autoworks
Your #1 Lexus Vendor
Meraki Autoworks's Avatar
Order them from us!!!
-Josh
__________________
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Old 10-20-17, 01:28 PM
Sheddy
Sheddy's Avatar
AFE Scorcher GT
http://afepower.com/afe-power-77-460...cher-gt-module
+24.63 WHP
+32.67 WTQ
Race mode adds +4PSI over stock.
Old 11-07-17, 09:52 AM
Pacific13
Pacific13's Avatar
I know that plenty of yours seem to be very interested only by Stage2 or Stage2+ but for people which does not wish to modify the car the Stage1 is also very interesting and performing.
Below the Dyno for both situations (stock/Stage1). The display was set to the same RPM allowing good comparative results.
For me with the TCM tune, it is very pleasant to drive and in Sport Mode/manual gear it is fantastic on little twisting roads.
Thanks again Tony for this job.
Sheddy (11-08-17)
Old 11-08-17, 06:34 AM
Sheddy
Sheddy's Avatar
Burger Tuning has a batch of piggy back systems in stock!
http://www.burgertuning.com/lexus_pe...nce_tuner.html
Old 01-09-18, 09:27 AM
Sheddy
Sheddy's Avatar
The best plug and play performance modification you can do to your RC200T!
Blue- Burger
Tuning Tuning
stage 1 w/ stock motor
Red- Stock tune
Blue- Burger
Tuning Tuning
stage 1 (BMS) w/ PPE down-pipe.
Red- Burger Tuning stage 1 (BMS) w/ stock motor.
Old 11-29-19, 10:27 PM
Krd8099
Krd8099's Avatar
Default 200t
Blue- Burger Tuning stage 1 w/ stock motor
Red- Stock tune
Blue- Burger Tuning stage 1 (BMS) w/ PPE down-pipe.
so what is the best set up for the most performance out of these engines
Quick Reply: 200T Tuning List
