Air Lift Performance Uneven rear height
Question guys, does anyone experience the uneven rear height? i just installed air lift performance 3h + BC coilover and my driver rear side is sitting lower than the right and the shop couldn't figure it out. Any help, please?
One thing you can do to test this, is to leave it in its manual setting overnight, take note of your PSI and then then check again in the morning. Everything should be the same. Also if your compressor is kicking on every time you turn on your car then you definitely have a leak.
Just a few things you can look into.
figured this out? i just installed mine and have the same issue as you. but mine is full air lift suspension
metaleckz
11-23-16 11:59 PM
BradTank
GX - 1st Gen (2004-2009)
19
01-24-13 05:21 PM
