Niche M130 Targa Rims
Old 04-13-18, 09:01 PM
Aetheryte
Aetheryte's Avatar
Question Niche M130 Targa Rims
Hello everyone,
I am new to the forum here, and also new to car upgrading/ putting on new rims etc, hence why I have decided to post and ask for suggestions. I am currently looking to put on some Niche M130 Targa rims on my 2015 RC 350 F Sport.
Rims specs:
Front - 19" x 8.5", offset +35, 5x114.3 bolt pattern, 72.6 mm hub
Rear - 19" x 9.5", offset +35, 5x114.3 bolt pattern, 72.6 mm hub
My current tires specs (currently using OEM/factory tires):
Front-235/40/19
Rear-265/35/19
*not sure on what's the default OEM rims/wheels offset is
I will be sticking to my OEM tires. now, I have some questions. Would this set up work (well)? Would the rims fit well? Any effect on the car's performance or how the driving feels with this setup? Will there be any rubbing? Do I need to lower the car height, or stock/current height of the car right now will work just fine?
I have seen many people's setup where they use higher offset value in the rear than the front, so I'm not sure if im doing this right (having the same offset value of +35 for both front and rear. I do not know if this matter). Let me know what you guys think!
Also, my RC 350 is a Nebula Grey, anyone have pictures of these M130 Rims on their nebula grey RC 350? Do you think they will look good? They look amazing on White and Blue 350s!
Thank you in advance!
grootds17
CT 200h Model (2011-2017)
10-12-17 07:29 PM
Lexislex
11-22-12 02:05 PM
Lexislex
11-22-12 10:12 AM
Bigkahuna
12
02-19-06 12:56 AM
Quick Reply: Niche M130 Targa Rims
